Master Bond
Electrically Insulative, Low Viscosity Epoxy
Master Bond EP3UF is a fast curing adhesive that passes NASA low outgassing requirements and is used for bonding and underfill applications. Discuss with a specialist.
Master Bond
UNDI Fabrication for IC Substrates
Reflow Oven and Wave Soldering Machine Maintenance Cleaning
Maintenance cleaning is imperative. Investment in a cleaning schedule and chemistry creates reliable processes to extend equipment life.
June 22, 2026 - Updated
December 3, 2025 - Originally Posted
Shielding Techniques When Removing Components Using Hot Air
When removing a component using hot air near heat-sensitive parts, what shielding techniques are most effective?
K.S.
We use aluminum foil as a shield around the heat sensitive parts in question and we also form the shape to conform around the heat sensitive part to help shield both the hot air as well as heat sinking the heat off the part in question. This approach works extremely well with minimizing heat absorption of the heat sensitive part / device. Also, if one need to understand the temperature rise on the heat sensitive part / device one can tape a thermocouple with Kapton tape to the heat sensitive part / device to understand the actual temperature rise that is being absorbed during the adjacent rework process.
This can be added proof that the heat sensitive part / device is not seeing a temperature rise / absorption that would or could influence long term reliability. We have also made aluminum machined heat shields that can be placed overheat sensitive device / parts that need a large heat sinking capability to protect very heat / temperature sensitive devices / components. Normal rework process shielding can be achieved with just using folded up aluminum foil to create the shape and shield necessary to achieve good results.
Mark McMeen
Mark McMeen
VP Engineering Services, STI Electronics Inc.
Openair-Plasma for Semiconductor Manufacturing
Openair-Plasma for semicon-ductor production is an alternative to vacuum plasma. Typical apps are wire bonding, die bonding & pre-molding. Download here.
The Essential Guide for High-Reliability BGA Component Re-balling
