SEHO Systems GmbH
SEHO Systems GmbH
August 18, 2026 - Updated
April 21, 2025 - Originally Posted
Low Operating Temperature Lead-Free Solder
We will be soldering copper wires inside a motor that operates in a cold environment at -200 °C and cycles up to 100 °C. Which lead-free solder alloy is designed to endure this temperature cycle range?
L/M.
I understand that Sn/In alloys are useful for low temperature applications as they maintain some ductility at low temperatures. Additives are carefully selected for Sn/In alloys to improve performance characteristics. I suggest contacting suppliers of those alloys for more information.
Tony Lentz
Tony Lentz
Field Applications, FCT Assembly
Usually solder is tested/cycled from -40 C to 150 C. I’d recommend you contact the solder manufacturer for information on a larger operating range.
Edithel Marietti
Edithel Marietti
Senior Manufacturing Engineer, Northrop Grumman
For soldering copper wires inside motors exposed to extreme temperature cycling from -200 °C to +100 °C, standard lead-free solders like SAC305 or SnCu are not suitable, as they tend to become brittle under cryogenic conditions.
We recommend using indium-based solder alloys, such as:
  • Indalloy 1E (52In/48Sn) – eutectic alloy
    • Melting point: 118 °C
    • Reflow: 135–150 °C
    • Excellent ductility and cryogenic reliability
  • Indalloy 290 (97In/3Ag)
    • Melting point: 143 °C
    • Reflow: 160–180 °CExcellent for thermal cycling and vibration resistance
Although we are not affiliated with Indium Corporation, they currently hold key patents and offer proven performance for cryogenic and aerospace-grade solders.
Other commercial brands to consider for high-reliability and specialty solder applications include:
  • AIM Solder (USA/Canada) – known for custom alloys and reliability testing support
  • Alpha Metals / MacDermid Alpha (USA/UK) – global supplier with strong R&D in automotive and high-temp solders
  • Senju Metal Industry (Japan) – top-tier Japanese supplier with indium alloys and cryogenic solder pastes
  • Tamura Corporation (Japan) – known for electronic-grade solders and specialty formulations
  • Koki Company Ltd. (Japan) – advanced no-clean and low-temp alloys
  • Stannol GmbH (Germany) – offers eco-friendly and specialty solders with traceability
  • Balver Zinn (Germany) – high-purity solders, including indium and silver-based options
Depending on your region and supply chain, these companies may offer equivalent indium-based alloys or alternative cryogenic-capable solutions. We recommend consulting their technical data sheets and requesting samples when possible.
Andres Rojas
Andres Rojas
Engineering Director / Master IPC Trainer (MIT), AMMSA Solutions
An indium-containing solder would be best for this very low-temperature application. In100 (100% In) is however extremely soft. For this reason, an alloy of 97In3Ag (97% Indium, 3% Silver) would be suggested for the added strength that the Ag provides. This does lower the melting point from 157°C to 143°C, however it should still meet the need for the top of your temperature range.
Process Engineer, Astronautics
BEST Inc.
BEST Inc.
