SEHO Systems GmbH
SEHO Systems GmbH
October 30, 2013 - Updated
October 22, 2013 - Originally Posted
What is a Soft Solder Joint?
We place many surface mount connectors. One of the methods of inspection is testing the sheer strength of the formed joint. Where can we find specifications to determine if the joint meets any standard for sheer strength. When force is applied to a pin using a metal probe and the pin moves, our customer rejects it calling it a "soft solder" joint. Is there such a thing as "soft solder." And if so what is the method of determining soft solder?
M.E.
According to Howard Manko, Solders and Soldering, page 142, theJoint strength of a lap solder joint is ((Length of the joint x yield strengthof the solder x the Width of the lead) or stated differently Strength = s x critical area where s is in either shear or tensionaccording to the configuration. From table 5-3 the shear strength of 63/37 is 5400 psi, theshear strength of 95Sn5AG is 6000 psi therefore using a lead of .020" wide and.10" long the formula from above the answer for tin/lead is 10.8# and for thelead free is 12#. When applying forces with a probe, consider the size of theprobe and size of your hand and the size of your forearm, and you are probablyapplying over 1000# of force to that solder joint, no wonder it moves. The strength of the solder is only that ,the strength of the joint,and it is good for comparative purposes only. Solder joints don't fail thatway, they fail by fatigue and stress loading, elastic failures. These elementsare tested using thermal cycling and or comparison of Coefficient of thermalexpansion and such. Soft solder is any solder that melts below 800F, above thattemperature the process is brazing and above those temperature the process iswelding. Probing the solder joint is not the way to test whether a solderjoint is good or bad as this is a bad practice and should be avoided. I hope thisinformation is useful and anyone wants to discuss this further, please contactme at your convenience.
Vice President, Technical Director, EPTAC Corporation
BEST Inc.
BEST Inc.
