Test-Research-Inc.
Test Research, Inc.
May 8, 2024 - Updated
May 1, 2024 - Originally Posted
Solder Alloy Investigation
Is there a test to confirm the precise solder alloy used on an assembled PCB? We need to rework components on assembled circuit boards but have no reference for the solder alloy, so we are not sure what rework temperatures will be needed.
R.A.
XRF (X-ray Fluorescence) equipment can provide detailed composition results without harm to the product. Circuit Technology Center, Inc in Haverhill MA. is a source that can support this service.
David Cormier
Engineering Manager
Manufacturing Engineer of 20+ years. Involved in Industries relating to all sectors of defense, Commercial product Industries, RF - Microwave and Semiconductor industries. Vast knowledge and experience relating Mil-STD’s, IPC-STD’s, EAI-STD’s, GEIA-STD’s, J-STD’s and MIL-PRF-STD’s.
The best non-destructive method for determination of the alloy used would be XRF (X-ray Fluorescence Spectroscopy). Many labs that service the PCBA assembly industry will have this capability as well as PCB fabricators. There are small handheld unit available by you would need to investigate the accuracy. If the product is labeled RoHS it is more likely than not that the alloy is SN100 or SAC305, but you can’t be sure without a test.
Kevin Mobley
PCBA Engineering Liaison
The precise alloy may be difficult to determine without sending a sample out to be analyzed. I believe it would be more important to determine if the solder is leaded or lead-free. This would allow you to solder within the ball park temperatures without risking damage to the board or components. Depending on what type of rework operation you are performing, you may try using just enough heat required until you see the solder starting to flow. If this is a circuit board with a large amount of ground plan, you should consider pre-heating the board prior to rework.
Brien Bush
Cirtronics Corp.
I do not know if there is a test you can do to determine the precise solder alloy unless you send a sample to a lab. For a quick test I’d recommend the following:
  1. Determine if the solder contains lead or if it is lead-free. There are several lead testing kits in the market. If the solder contains lead, you will either have 63/37 or 60/40 tin-lead alloy. These two alloys are the most common when it comes to lead solder.
  2. If the solder is lead-free, there is a high probability that it is a SAC 305 alloy. Again, I’m applying the same principle as I did with the lead solder. SAC 305 is the most used for lead-free solder.
Edithel Marietti
Senior Manufacturing Engineer
Northrop Grumman
XRF can be used to identify the major constituents of an alloy without damaging the solder joints. The solder could be physically removed, dissolved, and analyzed using ICP or AAS techniques. That would destroy at least 1 solder joint, but is a very accurate method of identifying the metallic constituents.
Tony Lentz
Field Applications
FCT Assembly
Yes, there are several test, but the easy and simple way to know the alloy and the elements of the solder joints is the XRF analysis. We can help to you on this and other test in our laboratory.
Andres Rojas
Engineering Director / Master IPC Trainer (MIT)
AMMSA Solutions
XRF testing can be used to determine the composition, or to detect the presence of a certain element in the alloy.
Amit Bahl
Sierra Circuits
