Ask the Experts | ||||||||||
January 23, 2024 - Updated January 17, 2024 - Originally Posted Full Aqueous Clean or Local Spot CleanWe use water-soluble solder paste for our PCBAs. After we perform component rework (removal/replacement), is there an industry recommendation to either fully clean the PCBAs by an aqueous cleaning machine or manually clean only in the reworked areas? T.S. |
I would strongly recommend full cleaning through an aqueous cleaning system preferably with a Proprietary cleaner to ensure proper cleaning and Neutralisation of the flux medium used. Local cleaning is very likely to spread activators under components and very unlikely you will remove 100% of these which will cause an issue in the field.
The standards say get it clean, they do not say how, for the most part. How clean depends on the application and or the customer’s requirements. A full wash and clean rinse assures the offending materials are completely dissolved and rinsed away. Spot cleaning can leave dissolved contamination behind once the liquid has evaporated. Unless you can fully rinse the spot with clean solution, you’ll just spread the contamination around vs removing it.
The amount of cleaning you do on your parts depends on the level of reliability that you are building your assemblies. If it is an assembly that is going into a system where there could be a risk of life, then by all means clean the boards in some type of cleaning system or machine. It doesn't have to be complicated. It could be an immersion, or quick rinse, in a good blended polar solvent, manufactured by Florachem, Vantage, or Kyzen, followed by a rinse with IPA. However, if your level of reliability is low, such as for Ground Serviced Equipment, then simply clean the reworked area with a splash of DI water, the follow it with a localized cleaning with a brush and IPA. The more you clean, the higher the reliability that the assembly will not fail. Leaving contamination on the board will always invite shorts through the dendritic growth, or similar problems.
I have seen far to many cases where local cleaning is not a removal of residues but a re-distribution of residues and failure follows. If you do not have water intolerant parts on your assembly, it would be best to follow with a pass through an in-line or batch cleaner.
With water-soluble fluxes it will be best to clean the whole PCB again. If you already have a water wash system why not use it? Spot, i.e., manual cleaning, especially on WS fluxes can be risky. How can you guarantee that the flux did not migrate away from the work area only to dry down under a flip chip or other low standoff components? Lastly, isopropyl alcohol and other common solvents used for spot cleaning are not effective on WS fluxes. Using the cleaning theory of “like clean like” WS fluxes require water or water-based solutions to be effective.
As you mentioned, cleaning can be done manually in the rework area or fully clean the PCBA in a washing system. In either case, water-soluble fluxes must be removed, unless they are tested and designated as “safe” to leave on the PCBA. Manual rework with liquid fluxes and gel fluxes lends itself to spreading of the flux away from the rework area. Manual cleaning may not remove all of the flux residue. It is best to fully clean the PCBA in a washing system to ensure that the flux residue is fully removed.
It depends on the extent of the rework. If the rework is done to a single component, hand cleaning is sufficient. If the rework is on multiple devices or a component such as fine pitch SMT leads, using an inline washer should remove flux and other contaminants efficiently.
President and Founder Contract Manufacturing Consultants, Inc. Robert Fried helps leading electronics OEM's develop world-class sourcing strategies for PCBA, cables, precision metals, plastics, modules and complete end-products. Other service areas are supplier risk assessment, comprehensive outsource ...
As flux vehicles of water-soluble solder pastes for most water soluble paste are highly activated (ORH0, ORH1), they have high corrosion potential, Any remaining flux residues post-soldering and have to be cleaned , usually using DI-water or an aqueous based cleaning mix. To make sure for post-rework assemblies all contamination is removed for good reliability, a full cleaning process within an aqueous cleaning machine (Inline or batch) is the preferred solution.
Product Manager Soldering Inventec Dehon Product manager for soldering products, including solder pastes, liquid and tacky fluxes.
IMO, spot cleaning can create additional contamination to the PCB. Re-cleaning the entire PCB is my opinion.
Water-soluble solder paste is mostly classified in ORH0 or ORH1 which are highly corrosive. Manual cleaning is a risk to spread the flux residue to contaminate the adjacent area. That area might get the corrosion from the leftover residue and have functional or reliability issues when the time pass by. The full cleaning process is recommended to ensure the water-soluble flux residue is completely removed from the boards.
Customer Technical Support Engineer Alpha Assembly Solution Mr. Srianan is a Customer Technical Support Engineer for Alpha Assembly Solution. He has 15-years of experience in SMT and soldering fields. He takes care of all technical inquiries and problems for customers in Southeast Asia and Australia.
Submit A Comment | ||||||||||
