Start Micro Dispensing Today
March 9, 2025 - Updated
February 8, 2023 - Originally Posted
Storage To Prevent Corrosion
Which storage method will better protect against corrosion, nitrogen or super-dry?
L.M.
Long-term storage of electronic components really is concerned with mitigating two distinct risks:
  1. Corrosion (oxidation) of solderable surfaces
  2. Moisture uptake (for moisture-sensitive devices)
Specifically for protection from oxidation, a cabinet with a dry-air atmosphere does very little. You need to eliminate oxygen from the atmosphere in the cabinet to eliminate it reacting with solderable metal surfaces. By far the easiest way to do this is to use a dry nitrogen purge. That gets you protection from both moisture uptake and oxidation.
Actually a combination of low RH atmosphere and nitrogen (low oxygen) will be the best at preventing corrosion. If your goal is only reducing corrosion, then nitrogen is good because it displaces oxygen. If you goal is also prevention of moisture absorption (MSL) low RH is best. Nitrogen is good for reducing oxygen and low RH is good for reducing moisture. Neither system can reduce oxygen or moisture (water) to 0% so as said, a combination of low RH atmosphere and nitrogen would be the best.
Paul Austen
Senior Project Engineer
Both are equally good at protecting against corrosion and oxidation, but you must have clean parts (low in ionic and organic contamination) post plating, rinsing and lead tinning. If you see corrosion on either condition the parts are very contaminated and typically the fabrication rinsing is the main source.
Terry Munson
Foresite
My recommendation would be a vacuum seal utilizing a nitrogen purge with a large desiccant pack.
Jerry Karp
JSK Associates
Concerning the prevention of corrosion, there is several reasons to consider depending on the factors causing corrosion:
Material surface – which kind of material is considered, is it sensitive to corrosion?
Residues that create acidic or alkaline environment – fluxes, cleaning chemistry, etching materials
Ionic residues – salts like sodium chloride
Humidity level – water presence often multiplies corrosion effects
Temperature storage environment for materials
Intermetallic effects – electrochemical migration
Corrosive gases environment
When reasons and influence factors are clearly detected, a strategy for corrosion prevention can be defined
Manuel Schöllig
Product Manager Soldering
Inventec Dehon
Product manager for soldering products, including solder pastes, liquid and tacky fluxes.
Both nitrogen storage and super-dry storage can be effective in preventing the corrosion of electronic components and printed circuit boards (PCBs).
In nitrogen storage, electronic components and PCBs are stored in an environment filled with nitrogen gas. This displaces oxygen and moisture, which are causes of corrosion, and maintains a low relative humidity within the storage container, reducing the risk of corrosion and ensuring the reliable performance of the components and PCBs.
Super-dry storage, on the other hand, stores components and PCBs in an environment with extremely low moisture levels, achieved through desiccant materials such as silica gel. The low moisture reduces the risk of corrosion and ensures the reliable performance of the components and PCBs.
While both storage methods have their benefits, nitrogen storage has the advantage of being more easily controlled and maintained as the nitrogen atmosphere can be managed more effectively than desiccants which can lose effectiveness over time. Hence, the humidity level stability over time is better in nitrogen and therefore the effect on corrosion is typically superior.
Dr. Eyal Weiss
CTO
Cybord
Electronic and Mechanical Engineer with 25 years experience in technology development. CTO of Cybord, developing electronic component authentication technology using deep-tech visual inspection and big-data. Author of a book and 24 papers.
Corrosion is caused by oxidation. You need an atmosphere of oxygen & water for corrosion to begin. Nitrogen is an inert gas that will not react with metals. When Nitrogen purges Oxygen from the atmosphere there is no chance for corrosion. On the other hand, a super dry atmosphere will also help to avoid corrosion since air humidity is kept to a minimum. Both processes will protect from corrosion but first you need to know how susceptible the material is to oxidation.
Edithel Marietti
Senior Manufacturing Engineer
Northrop Grumman
Specifically for corrosion prevention, nitrogen use is the way to go.
Georgian Simion
Independent Consultant
Touchless Solder Ball Removal
