Start Micro Dispensing Today
March 15, 2024 - Updated
November 2, 2022 - Originally Posted
How To Remove Oxidation On SMT Components
What process do you recommend for removing oxidation from SMT components? These components are unsolderable due to the surface finish. See the image.
R.J.
Using a solder dipping or dragging process using an aggressive flux would help to restore solderability to the component leads. If the solder applied to the leads is not planar, then placement during SMT may be difficult due to non-planarity.
Use of a more aggressive solder paste, like a halide containing water soluble, may enable soldering to the oxidized leads.
Tony Lentz
Field Applications
FCT Assembly
This is a challenging problem. It depends on the qty of parts and cost. You can apply a more active flux just before solder reflow but recommend running a few parts to verify solder results. Changing solder paste with a higher flux activation level should also be considered but could require flux removal after solder reflow if user is currently using no-clean flux solder paste.
Robert Freid
President and Founder
Contract Manufacturing Consultants, Inc.
Robert Fried helps leading electronics OEM's develop world-class sourcing strategies for PCBA, cables, precision metals, plastics, modules and complete end-products. Other service areas are supplier risk assessment, comprehensive outsource ...
I recommend removing the oxidation on the leads before installation using a Robotic Hot Solder Tinning service. A mildly activated flux will assist in breaking down the oxidation, and the dynamic wave will act as a scrubbing and solder replenishment application. Circuit Technology Center in Haverhill, MA, can return the devices to a fully solderable condition with quick turn options.
See the below link for a short video of the process.
https://www.circuitrework.com/services/tinning.html
David Cormier
Engineering Manager
Manufacturing Engineer of 20+ years. Involved in Industries relating to all sectors of defense, Commercial product Industries, RF - Microwave and Semiconductor industries. Vast knowledge and experience relating Mil-STD’s, IPC-STD’s, EAI-STD’s, GEIA-STD’s, J-STD’s and MIL-PRF-STD’s.
It is always difficult to remove oxidation once formed and is dependent on how safety critical the devices are. Ideally the components should be hermetically sealed under vacuum or in nitrogen atmosphere with moisture absorption thrown in just to be on the safe side. Once opened the bag components should have a realistic shelf life and a known process to either re-seal in a new bag or stored in a nitrogen cabinet to prolong the life as long as possible. But in the real world this is very often difficult.
Take a step back and determine if the risk of a field failure is acceptable against the cost of buying fresh components or doing the work to try to re-use old components. If you cannot source the components anymore then this becomes a fairly straightforward choice as below.
You can look at companies that will re-plate or clean the devices, the beauty of this is that if it goes wrong you have some limited opportunity to get them to do it again to make it work better.
But essentially if this is something you are doing in house then your options are limited.
  1. use a more aggressive flux when soldering. This requires you to either test to ensure it does not compromise the lifetime of the product or clean the finished product to ensure that there are no long-term reliability issues.
  2. Re-tin re-plate the components. This can be done (depending on wat equipment or skill level you have) by dipping in a pot of molten solder or using a solder wire and an iron just to add solder to the component which will freshen it up. Depending on the materials used you might have to do some cleaning of the components after touch up to ensure that they are safe to use on your product and all the chemicals / flux are removed.
Given the choice and depending on the risk level you are willing to take, getting a third party to do this takes away some of the issues and worry of doing it yourself.
Richard Boyle
Global Product Champion
Henkel Electronics
If oxidation is the only impedance to solderability, a “good” flux should remove it. Ask your favorite flux/paste manufacture for advice. If the solderable finish on the lead has been removed or destroyed, it may need to be replaced and there are companies that specialize in refinishing/re-tinning SMT leads.
Paul Austen
Senior Project Engineer
I’d start out with a low activity flux and inspection. If that does not work move to medium activity flux and then remove any leftover flux with Isopropy Alcohol. Make sure the leads are free of any flux. Use a solder pot to tin the leads to check for solder adhesion.
Edithel Marietti
Senior Manufacturing Engineer
Northrop Grumman
Assuming that the parts are 100% tin plated, the oxide can be reduced using a solution of Thiourea and HCL. If the Sn has been converted to CuSn IMC then you will not be able to save the surface finish and will need to have the parts retinned.
Gerard O'Brien
The best option would be to re-tin the parts if they are not expensive, replace if they are hard to get or expensive. I would try re-tinning with a mild flux and progress to a more active flux if needed. Going to a more active solder paste could help the problem but often a paste is qualified with a customer or your internal process for cleaning a highly active flux may not be verified.
Adding a liquid flux before reflow may not help a lot as the flux elements in paste are designed to survive the reflow ramp and soak, liquid fluxes are designed to activate more quickly and may not prevent or remove oxidation after the reflow profile exceeds 100C or so. All of the active flux elements of a liquid flux may be driven off by that point.
Kevin Mobley
PCBA Engineering Liaison
I could not see the image but offer the following.
If the condition is truly an oxidation of the surface finish, an easy way to fix the problem is to retin the component leads using a more aggressive flux than the production flux. Loose components are easily cleaned in water solvents so this would not impact the reliability of the assembly as they are assembled to the product.
If this does work, then depending upon how many components are in this condition, they could all be sent to a tinning house for retinning.
There are companies specialized on tinning services – depending on the components and applications, caution is recommended as the chemical and thermal processes can cause parts problems (immediate or latent failures) Internally, a more aggressive flux than the current one might yield good results – the same caution as above is advised.
Georgian Simion
Independent Consultant
Touchless Solder Ball Removal
