May 1, 2024 - Updated April 19, 2022 - Originally Posted Coils Rotated After Reflow
Y.I. |
Is this being dragged round by internal baffles/curtains as its quite large?
Possibly a high center point under the device. Verify that the device sits flat and favors the leads contacting on a flat surface. You may also use a Loctite staking material to prevent this issue.
This is a thermal issue, resulting from the reflow of the solder paste and the design of the termination beneath the component. If the pad is not symmetrical, as the solder melts the surface tension of the molten solder will pull the component to where the maximum amount of solder is situated on the land area. This will cause the component to move from its original placement. I suggest looking at the stencil and see where and how the paste is dispositioned beneath the component, and it may be worthwhile to rearrange the stencil openings to be more conducive to creating or allowing an even distribution of the solder paste on the board.
There are 2 scenarios:
Director of Sales and Marketing Sierra Circuits Amit Bahl started to work at Sierra Circuits in 2006 where he formed strong relationships with his customers working with them on flex PCBs, HDI, controlled impedance, etc. In 2009, he was promoted Director of Sales and Marketing.
If the component is placed centered on pads, the reflow process can cause the part to "float" on the pads - pad design review can help with that but a simple adhesive dot under the part will eliminate the headaches.
