September 21, 2023 - Updated February 3, 2021 - Originally Posted BGA Component Cleaning SpecIs there a standard or or specification covering requirements for BGA cleaning after rework? E.C. |
IPC/EIA J-Std-001 "Requirements for Soldered Electrical and Electronic Assemblies" section 8, "Cleanliness Requirements" address these post soldering cleaning which I think it safe to assume applies to all post solder cleaning whether post-reflow/wave soldering or post-rework soldering and also regardless of the component type.
The dedicate standard to BGA processes is the IPC 7095. Its important understand the full process and take in considerations all the variables and try to reproduce at moment of repair and rework to get the best result and meet the standard criteria IPC-610. The IPC-7095 standard internally call to IPC 7711 & 7721 to techniques repair and rework and IPC-610 to acceptance. The cleanliness criteria are a little bit ambiguous, because is focused only on visual inspection. My recommendation is meet all the IPC standard statements and recommendations for process, rework, repair and visual acceptance. In my experience one of the most important think, is the materials selection (flux, solder, solvents, wipes , tooling etc.) this need to be fiber and dust free, halide free, low halide or zero halide to minimize the reliability issues.
Engineering Director / Master IPC Trainer (MIT) AMMSA Solutions More than 20 years of technical experience in the electronics industry in roles ranging from Process & Project Engineer to engineering manager and Technical Applications Engineer for Latin Americas. IPC Master Trainer, International speaker and consultant.
I would say that the cleanliness requirements after rework would be the same as those imposed by the user as part of the initial requirements. IPC J-STD-001 Section 8.3.2 would cover the specific requirements unless the user has specified something different.
