AI-Technology-Inc
AI Technology
Creative-Electron
Creative Electron
September 20, 2024 - Updated
August 19, 2020 - Originally Posted
Seeking Advise for a Solder Reflow Recipe
I have a new product coming in and need some ideas on reflow recipe creation. The pcb has a .040" copper core with 2 oz. copper on the top layer and 2 oz. copper on the bottom layer, sounds like a tough challenge. My reflow oven has 7 zones though so I think it is possible, any advice would be great.
W.K.
You are right, given you have 7 zones, you have a fighting chance. You will most likely need to set up a Ramp-Soak-Spike profile, committing typically Zone 1/2 for Ramp section, Z3,4,5 for soak and Z6/7 for reflow. This allows you to drive a good amount of heat into the board in the Ramp, then time to Soak/equalize as best as possible minimizing any temperature differences across the assembly before reflowing. Selecting a paste with a generous working window would also help, if you have wildly differing thermal mass components or any temperature sensitive components it will be a challenge.
Ultimately you will need to perform some thermal profiling, if you are currently using linear ramp profiles you are going to have to make a best guess – otherwise start with a ramp soak spike shaped profile and go from there. It is likely you are going to have to slow the conveyor speed from what you normally use – this will allow temperature settings for the zone to be more achievable.
Adjacent zone in a reflow oven should not exceed typically < 40C, as the two zones will struggle to maintain differentials, this maximum zone delta value may vary oven to oven.
Your oven manufacturer/supplier is best person to suggest a starting point zone for temperature/speed – as they are most likely to have seen similar boards and all ovens perform differently - but it will only be a starting point.
In Solderstar profiling tools we have automatic prediction tools to help establish the best profile settings, once we have captured a profile from a test PCB and the oven – our software creates a mathematical model which can simulate oven and speed changes and drive towards more optimal solutions. We also have the ability to define individual process specifications for each measurement channel/components – so if you have a special/sensitive component we can define special limits for those areas.
Mark Stansfield
Founder / Director
SolderStar Ltd
Co-founder and M.D of UK based thermal profiling equipment manufacturer SolderStar Ltd. He has software and electronic design experience specifically in the development of thermal profiling solutions for the electronics industry.
The short answer is you will need to increase your zone temperatures and/or lengthen the heating time (slowing the conveyor speed). There are several thermal profiling packages that include software prediction features that can help you with developing a robust reflow recipe (like ECD's M.O.L.E. MAP software), and these would be a good place to start.
Knowing the copper weight of the PCB material is only a small part of the equation though, as the layers between the copper are insulators. Other variables to take into consideration are component densities and types, potentially thermally sensitive components, solder paste recommendations, your specific oven's ability to heat (regardless of zone counts), etc..
The only way to KNOW your thermal profile is correct is to measure it on an actual assembly. If you don't have a sacrificial assembly to use (ie: the customer won't allow or too costly), then you should attempt to replicate the assembly with like type board and components. This won't be exact, but at least this will be a better representative than a bare board.
Mark Waterman
M.O.L.E. Line Product Manager
A thermal profile will be the best tool to help you find the right oven recipe.
One thing for sure, no matter the recipe you end up with, a thermal profile of the assembly will be needed to determine if you are reaching the required temperatures and times. The hardest part will be heating the copper core, since it has layers of insulation (PCB material), which will slow the heat flow to the inner core. Try a "standard recipe" to start with and run a thermal profile to see where you stand. Because the PCB layers of insulation will slow the temperature rise of the core, more than likely you will need to reduce the conveyor speed a bit to make up for the thermal flow slow down.
If decreased conveyor speed is not possible, increasing the convection fans or air flow/pressure may also help, if your oven has this capability. But remember, increased convection rate will NOT be as effective, because of the insulation layers over the core will still slow the heat flow to the copper core. Increasing the zone temperatures is your last resort, but this can begin to risk the temperature sensitivity of the component, which are exposed (no insulation) directly to the oven's heated zones.
Again, thermal profile this assembly after each oven recipe change to make sure you get it right.
Paul Austen
Senior Project Engineer
The heavy copper plane (0.040") will certainly act as a heat sink resulting in lower measured reflow temperatures than what would be expected from a typical (non-copper plane) circuit board. I recommend a slow reflow profile with approximately 5 minutes from ambient to peak temperature.
I also suggest running a soak type profile with 60-120 seconds of soak time between 150-200C for lead free soldering. It is important to place the profile thermocouples on cool and hot spots across the circuit board surface. Your solder paste supplier will be able to recommend reflow conditions and advise on what the solder paste can handle if it is necessary to run reflow outside of normal recommendations.
Tony Lentz
Field Applications
FCT Assembly
A portion of the Solder Reflow Fundamentals class that I teach at SMTAI describes how to choose a starting recipe.
It lists the following methods:
  1. SWAG - based on skill, experience and luck;
  2. Start with a known recipe for a board and solder paste that is similar to the new one;
  3. Have someone else do it;
  4. Use predictive software that is included with many thermal profilers;
  5. Use software that is provided with some reflow ovens - such as BTU's Recipe Pro.
In all cases it is imperative that a thermal profile of the actual board as it goes through the oven is obtained to verify the results.
Fred Dimock
Manager, Process Technology
BTU International
You should be able to do this with a 7-zone oven if it is a pretty good convection oven. You may have to slow it down a bit. You can help get the heat in by going a little warmer on the early zones than you would normally do.
Due to the mass this assembly will likely heat slower and you will see a similar early profile to typical FR4 boards. Also note that it will take this one longer to cool down, so you will need to watch the back end of the profile to make sure you aren't too long on the duration.
These will be hotter than normal coming out of the oven so watch the handling. Be sure to get thermocouples on any solder joints on ground planes as they will likely heat slower than other solder joints.
Kevin Mobley
PCBA Engineering Liaison
I have been using a 7-zone convection oven for more than 20 years and based on my experience, the PCB you just described, the best profile method to use is Ramp-Soak-Spike (RSS). Its challenging but not an impossible task. I would recommend Increasing Ramp temp but reduce soaking time then proceed to spike immediately once the PCB reach thermal stability. It is imperative that the paste will not lose its activator. The solder paste will play a big role in achieving the desire solder quality.
Depending on the type of components mounted on the board, Water soluble Solder paste (aqueous base) can help mitigate the process due to its aggressive flux content compared to no clean flux used now a days. However, proper cleaning is a must. Leaded solder paste such as Sn-Pb is better to use if the assembly is not bound to be Leadfree/RoHS assembly since its melting point is lower compare to Leadfree Solder such as SAC 305. I have seen an increasing number of complex board design year over year. Pushing the limits of convection oven reflow. For the past 10+ years our group look at alternatives for reflow.
Well, we do run convention, more and more we are moving to using Vapor Phase Reflow in our manufacturing process. Processing a metal core PCB regardless of how many ounces of copper, will solder the assembly without the possibility of overheating the components since the whole process doesn’t exceed 237°C. The temperature is distributed evenly across the assembly during the reflow process where the Delta-T is zero. Not to mention that the whole soldering process is zero oxygen. Due to these unique features, the result is exceptional and consistent. Eliminating or at a minimum (dependent on scenario) allowing for smooth production of limited rework. Therefore, soldering components on a heavy copper PCBs are no longer a challenge for us, using Vapor phase.
Jose Pineda, Trilogy-net
Viscom
