July 18, 2024 - Updated June 23, 2020 - Originally Posted Mixed MSL BakingIf the highest MSL-rated component on a PCB had a 27-hour bake time at 125C (1.4-2.0mm, MSL 3) and the PCB had to be baked to replace a different component that required an 18-hour bake time (1.4-2.0mm, MSL 2), what is the preferred avenue of approach? 1. Bake the PCB for 27 hours at 125C because that's the highest rating of a component on the PCB, regardless of the component needing rework. OR 2. Bake the PCB for 18 hours at 125 because that's the rating of the component needing rework, regardless of the other components. B.B. |
Thanks for the interesting question. I believe the answer lies with the component to be replaced or reworked. If that component has a specific MSL rating and is already mounted on the board, then follow the requirement for that component. The reflow profile should target that specific component so the other should not be damaged. If the component is to be replaced, then verify the dryness of the component and install it with the unique product thermal profile.
Bake to the higher MSL device/Board listed. The reason is the board and surrounding components most likely will see higher temperatures than the 125°C required for the MSL listed during rework and this will remove any risk. Something to consider is if any secondary components on the board are temperature sensitive, as in connectors, batteries, etc.
Need a little more information regarding the situation. E.g. what type of rework is going to be performed (hot air, IR, solder iron), how will the part with the higher MSL be effected by the rework, is there a means of shielding the part. We have gone away from forced air rework equipment and are using IR wherever we can to focus the heat on the component being reworked and we also shield any specifically sensitive components. If the plan is to heat part with the higher MSL and there is a concern, then I would suggest playing it safe and baking longer. But again I would need more information regarding the rework process to give sound advice.
Unless you plan to re-heat the entire PCB assembly to reflow temperature during the re-work process, you only need to bake the PCB assembly long enough to meet the bake requirements (J-STD 033) for the component being re-worked/replaced, and or any other components near the re-work area that MAY also reach reflow temperature, and whose MSL is the same or higher than the component being re-worked/replaced. If you are replacing the component, then who cares if that component it baked prior to removal, assuming you are going to throw it away. The new component being added however, must have been kept "dry" or baked per J-STD 033 prior to reflowing it onto the PCB during rework.
The safe bet would be to bake the assembly long enough to satisfy the most stringent requirement. If the component requiring the longer bake could be isolated or protected from the rework process, you could probably get by with the shorter bake cycle. Depends on the component proximity and the rework method.
If the level 3 component is already placed on the pcs (completed assembled board) then the second avenue is recommended. The reason for baking is assuring moisture is not present in the component anymore while reflowing it.
