October 2, 2024 - Updated February 26, 2020 - Originally Posted Wet Based Stencil Cleaning or Dry Wipe Stencil CleaningFor automatic under-stencil cleaning there are many cleaning methods including dry vacuum cleaning, and wet dry vacuum cleaning. What factors should we consider to select wet-based cleaning vs. dry-based wiping? Is it related to the amount of residual inside the aperture walls and the bleed out under the stencil? What are the typical cleaning cycles for both cleaning methods? I heard from some printer experts who say wet-based cleaning removes the flux from the stencil aperture walls and this flux enhances the paste release through the stencil, therefore they want to minimize the usage of wet-based cleaning. S.A |
There are many ideas on this subject. From my experience as a onetime solder paste developer is the stencil cleaning chemical compatible with the solder paste that is being used. If it is not you may create a gooey mess that will not remove paste residue easily. This will lead to insufficient prints as the paste will stick in the aperture and the next print will be insufficient. Assuming the chemistries are compatible, and vacuum is available, wet wipe then dry wipe then vacuum wipe. In the absence of vacuum; wet wipe thane dry wipe. If you are still having solder paste release issues, poor print from blead out or insufficient deposits, remove the stencil and check the bottom for dried paste or coined on solder spheres. This can be removed with a razor blade if needed be.
I would only recommend wet clean, then vac, then Dry. Using a 50gsm material not 68gsm. Seen too many Dry wipe, Vac, Wipe just smear the Paste powder underneath the Stencil, causing all kinds of issues, even bridging in the worst cases.
Underside stencil cleaning should be performed based on the solder paste supplier's recommendations. We recommend using a 3 part cleaning process including a wet wipe followed by 2 dry wipes with vacuum. It is important to use an appropriate solvent for the wet wipe to loosen and remove the solder paste from the bottom of the stencil. It is likely that some of the solvent will mix with the solder paste inside the apertures, and it is important that the solvent contaminated solder paste be removed from the apertures. That removal is accomplished through two dry wipes with vacuum. The material used for wiping will also affect this cleaning process. Some materials are better at trapping and holding solder paste than others. I suggest working with your cleaning chemical supplier and wipe supplier to get the optimal cleaning and wiping materials for the solder pastes used.
I've always used a combination of wet & dry. Many of the newer model printers allow you to choose any combination but before you choose there some questions you should answer to determine your cleaning process:
Having the answer to these questions will help you determine the best under stencil cleaning for your process. For example, in my case, I have laser-etched stencil, 21 mil pitch components, 2 large BGA's and type 3 NC solder paste. We set the stencil at Wet, Wet, Vacuum, Dry; every 10 assemblies and have no issues.
The most important factor is the type of solder paste flux you wish to use. All of the experts have good comments, but the most important one is to discuss this with your paste vendor. Yes, having a little bit of soluble flux left behind can help with paste release, but the caveat is that it depends on HOW LONG that water soluble flux is left on. If more than a few minutes it will do more harm (entrapment from being sticky) than in promoting release.
Odin Stadheim, Skarnes Teknik AS
Conversely, if you are using a no-clean or RMA-based flux in your solder paste, well then you certainly want those apertures be completely clean and dry after each print, because those fluxes can be incredibly sticky right out of the container. It is far better to depend on a good stencil with a good final nanofinish for paste release properties, that is the second most important factor. Once you have those two factors covered, then the sequence of wet/dry wiping is easily easily evaluated and qualified to see which works best for each paste/flux type. |
