February 26, 2025 - Updated June 27, 2019 - Originally Posted Maximum Allowable Time Prior to Washing When Using Water Soluble PasteWhen using a water soluble paste, after SMT reflow, what is the maximum allowable time prior to washing? Also, is the maximum allowable time any different when using leaded or lead free paste? What should be done with assemblies if they are not washed within that maximum allowable time? M.M. |
Many water soluble paste fluxes are acidic. I would not leave it on my board one second longer than absolutely necessary. However, whether it is because of its potential corrosive effects or if its effective removal is reduced if left on too long, it will depend on the chemical makeup of the paste flux. You must consult the paste manufacture or the published specification. Myself, I would wash it immediately after solder.
This is often an issue that is driven by the "end of shift, can I wait until tomorrow to wash these?" scenario. It may also be that there is the desire to process the boards through any subsequent solder processes and clean it all in a single wash cycle. Always refer to the recommendations of your solder paste supplier. I've seen data sheets that say it can wait anywhere from 8 to 72 hours after reflow before washing. Although OA flux residue is normally much easier to clean than rosin-based residues, note that the residues will not get any easier to remove as time passes, as they sometimes harden up over time. I'd suggest washing earlier than later, though you may be able to complete post-SMT solder processes provided the boards don't wait around for a period that exceeds your paste supplier's recommendations.
The maximum allowable time for washing a water soluble solder paste depends upon the solder paste itself. The manufacturer can give specific recommendations for this. Generally speaking washing within 4 hours is preferred, but 8 hours is acceptable. Some solder paste fluxes can be washed off after 24 hours, but this is not recommended. It is also advisable to wash off the flux reside after each reflow, e.g. wash after each reflow for double sided surface mount products. Tin-lead and lead free fluxes may have different recommended times between reflow and wash, but again this is dependent upon the suppliers recommendations.
It is difficult to provide guidance without knowing more information such as is the factory environment such as temperature and humidity controlled, is excess solder paste removed from stencils and re-used, etc. The best approach would be to contact your paste supplier and obtain their recommendation since they know the specific chemistry and working life of their solder paste
Our requirement for time between a dual sided reflow and cleaning water soluble paste has been 48 hours since 2008.
