Test-Research-Inc.
Test Research, Inc.
January 17, 2025 - Updated
April 2, 2019 - Originally Posted
Cleanliness Requirement for Populated Printed Boards
Has anyone performed a Cleanliness Requirement for populated Printed Boards per VDA 19.1. A customer is requesting that we meet VDA 19.1 but I don't think it would apply to PCB assemblies. I would think IPC 610 would be called out not VDA 19.1.
W.H.
W.H. an interweb search shows this to be a European requirement for German automotive OEM's. The title is, "Inspection of Technical Cleanliness - Particulate Contamination of Functionally - Relevant Automotive Components".
The document can be purchased at this link.
https://www.en-standard.eu/vda-19-inspection-of-technical-cleanliness-particulate-contamination-of-functionally-relevant-automotive-components/
Used for determining the particle contamination of functionally relevant components in the automobile industry.
This is common for engine and transmission components or other components exposed to fluids but I find it unusual to see it applied to a finished / populated PCB. Maybe your customer can provide you a .pdf copy of the requirement.
Charlie Pitarys
Kyzen Corporation
The standard referenced in the question is VDA 19.1 Inspection of Technical Cleanliness-Particulate Contamination of Functionally Relevant Automotive Components. A more common cleanliness standard for post-reflow circuit assemblies is IPC J-STD001-G, including the new Amendment 1 located in Section 8.
I am hosting a webinar on "Understanding the New IPC J-STD 001-G Amendment 1 Cleanliness Testing Standard" on April 16. Register here: https://register.gotowebinar.com/register/8948432954572791564
Mike Konrad
Aqueous Technologies
VDA 19.1 is for metal hardware and not PCBAs. IPC 610 should be used to identify particle risk per class 2 and 3 conditions. The real cleanliness risk on electronic hardware is ionic and organic residues. From fabrication assembly fluxes not heated adequately to create a benign residue and contamination trapped under a component.
Terry Munson
Foresite
