March 28, 2019 - Updated March 20, 2019 - Originally Posted Is There a Spec for LDI Mask thickness?Is there is a spec for LDI mask thickness? We build very small circuits with fine pitch small ball flip chips with very limited wet out area for the underfill. We have a very controlled underfill dispenser, but the gap (typical 4 mil) can vary with the mask thickness up to 30+%. If the mask comes in thick, the gap is reduced and the set volume of underfill has difficulty flowing and extends past the wet out area. T.G. |
The generally accepted spec for LDI mask thickness is dependent upon the copper thickness within the circuit. For example these are recommended guidelines: Copper Thickness Min/Max Mask Thickness 35µm 5µm - 15µm 50µm 5µm - 15µm 75µm 5µm - 15µm 105µm 5µm - 20µm 140µm 5µm - 20µm You might also want to consult your underfill dispenser supplier for their recommendation. I would also suggest contacting Nordson Asymtek as they have extensive experience with numerous dispensing applications including underfill.
Is there a released spec for the mask recommendations? I am guessing by the amount of responses there is very limited rules for mask other than minimum. I am using an Asymtek and it performs very well! Just have issues when the mask comes in a half mil thick or thin on a 3 mil gap flip chip. The same amount of underfill may or may not be enough or to much.
Tim Griebel, Starkey Hearing Technologies
