July 17, 2024 - Updated February 28, 2019 - Originally Posted BGA Component Grounding ProblemWe have an ongoing concern regarding reliability BGA components. Over the last year, we had boards returned due to a BGA issue. The boards use leaded balls, and leaded solder. All the boards show a resistance to ground at a data point of 3K ohms. A look at "good cards" shows a resistance of 3M ohms. X-rayed extensively and no issue found. We remove the BGA from the card, and now both the BGA as well as the board show the proper 3M ohms. Each time, after the removal of the BGA, the data point path to ground problem goes away. Essentially we somehow lost the failure signature. Can you offer guidance? M.S. |
Have you cross sectioned the BGA looking for head in pillow HIP? There are a lot of issues that X-RAY will not show.
his maybe useful especially if you are using 0.004" thick stencils. I have seen (last six months) many issues of failures and when investigated there is nothing to see under Xray analysis of a few manufacturers BGA's. We found another reflow again with a low solids Rosin flux liberally applied under neath the reflowed device or Rosin flux paste all around the BGA fixed the issue. I'm pretty sure of the devices I have looked at the BGA balls on a number of pads are miss sized and when using a 0.005" Stencil it's enough to accommodate the miss size whereas the 0.004" is definitely not OK. If you have to use 0.004" Stencils then over print the Paste and allow it to pull onto the pads again making up the gap produced by the smaller balls. Hope it works
If the cause of your high resistance failures is not apparent using microscopy or X-Ray, you will probably need to perform dye & pry and/or cross-section analysis of the interconnects.
Perform an Dye-n-Pry test on BGAs. It should identify any cracks or separations within the solder joints that could lead to false results. IPC-TM-650 Method 2.4.53 specifies a process for dye-n-pry.
PCBA Industrialization Schneider Electric Have 18 years of experience in electronic Industrialization. Specialties in PCB Design & manufacturing process, PCBA Process Development and Continuous Improvement.
It sounds like what is happening is dendritic growth. Over time, in the presence of moisture and ionic contaminants, a conductive path can form between conductors that are at different potentials. The 3k-ohm resistance is still relatively high for a dendrite, so you probably have very limited dendritic growth. When you remove the part, you mechanically disturb the microscopic dendrites, and unless significant corrosion has happened, the failure site is then difficult or impossible to find. The "good" resistance of 3M-ohms actually seems very low as well. Normally, I'd expect a resistance above 1 G-ohm. A resistance of 3M-ohm to ground will result in a small current always passing through that path, which can drive transport of metal ions, and eventually lead to a drop in resistance and failure of the circuit. Some of the most common contributors to this type of failure are:
If you are having issues at only a single data point and the issue is lower than expected resistance to ground, it may be that there are some flux residues allowing a secondary voltage/current path to ground, effectively reducing the resistance reading. If you are using an RMA or No-clean solder paste or flux, then I would even bet money on it. One way to check this is to simply remove the failing BGA and inspect the area for flux residues. If none are seen, then perform site prep by applying flux and wicking the solder off of the BGA pads and clean the area thoroughly but do NOT replace and reflow the new BGA. Instead, simply place a new BGA onto the pads and press it down lightly and have someone measure the resistance at the data point. If you now have the required 3 Megohms, repeat the process with perhaps 10 more BGAs using that same assembly as a "test fixture", so to speak. If all 11 BGAs display 3 Megohms, then lightly flux the pads with a good water-soluble tacky flux, solder one of the known-good BGAs onto the assembly, clean it thoroughly followed by an immediate blowoff to remove as much water as possible, bake it dry at 105 deg. C for 20 minutes, and test again. If it tests good, do the same thing on 10 more assemblies with the 10 remaining known-good BGAs. If they all pass, you can safely assume the issue was flux residues allowing the voltage to leak to ground. If any should fail, then there is some other issue with the BGA caused by reflow.
