DL-Technology
DL Technology
AI-Technology-Inc
October 11, 2024 - Updated
October 23, 2018 - Originally Posted
BGA Reballing Question
We are a mil contractor and have requirements to have BGA components reballed. The BGA components are supplied with SAC305 solder and will be reballed using tin-lead solder. Our reball service supplier uses a single dynamic solder wave to strip the lead-free solder balls prior to application of new tin-lead solder balls. This dynamic wave contains 63-37 tin-lead solder.
Is a single wave stripping process acceptable, or should the reball service supplier run the BGA components through a second pure tin-lead wave to ensure the any lead-free solder residue has been sufficiently purged prior to reballing?
W.M.
Great question. Our company provides BGA re-balling services and a robotic system configured with a single dynamic wave will sufficiently purge devices of lead free solder prior Sn/Pb sphere attachment. As others have mentioned, the purity of the solder pot needs to be monitored and tested regularly in accordance with J-Std-001 to validate the solder composition of the solder pot.
XRF testing can be completed Post de-ball and post re-ball to verify the Sn/Pb composition of the pads, and new spheres; many customers BGA re-ball specifications call for this testing step to be completed post processing. In some cases, customers will also stipulate that one device be cross sectioned (DPA, Destructive Physical Analysis) using a Scanning Electron Microscope as an additional verification of new sphere composition. The allowable limits related to solder purity in a Sn63Pb37, Tin content of ±1.5% alloy is in section 3.2.2 and Table 3-1 of J-STD-001.
All users should validate their processes as temperature, alloys and time are all considerations of dissolution rates regarding the use of a dynamic solder dipping process.
Bob LePage
Sales Engineer
Mr. LePage has been a key member of the team at Circuit Technology Center since 1996. He has vast expertise, experience and understanding of complex circuit board rework, repair and modification operations. He is one of the most knowledgeable experts in this area across the globe.
In my opinion, the additional thermal cycle would have much more negative impact to the BGA than would the residual Silver and Copper from the original SAC305 interconnects. The residuals would not be significant.
Rick Kompelien
Principal Product Engineer
Benchmark Electronics, Inc.
30+ years of experience working with electronic and electro-mechanical manufacturing and design (medical, automotive, military, computer, and industrial controls). Military veteran - served as a Combat Engineer with the United States Marine Corps.
The concern of course is, as the alloy in the stripping pot gets contaminated with Pb-free solder, the remaining solder will also be contaminated.
One way to look at this would be to examine the extreme condition where the entire contents of the stripping pot were replaced with the Pb-free alloy. Making some generic assumptions on pad geometry and ball size using typical dimensions for a 0.050" pitch BGA:
  • Pad diameter of 0.018"
  • Average solder thickness on pad after removal of 0.0007"
  • Replacement ball diameter of 0.025"
Based on the above assumptions, I calculate that in the worst case the final ball composition would be:
Sn 64.17%
Pb 35.71%
Ag 0.10%
Cu 0.02%
The contamination level for Ag would be at the maximum per J-Std-001, and the level for Cu would still be still acceptable. The composition of Sn and Pb would shift more than allowed under J-Std-006, however. The maximum allowed deviation for Sn and Pb is 0.5%.
The observed shift would be a little over 2 times the allowed shift, so the pot would need to be contaminated severely (About 40% Pb-free alloy) in order to take the final alloy out of specification. This is conservative, as I have (intentionally) not accounted for the solder paste volume in final assembly which would shift the alloy back toward nominal to a small degree.
Additionally, if the re-baller is using an air knife, the remaining solder thickness may be smaller than in the above example.
I have not seen this method of removing excess solder prior to reballing but the use of flux sprayed to the surface and dynamic wave action will remove any excess solder. To do it twice is something that needs to be checked out to see what qualify process control they use to determine a single pass is sufficient.
Robert Freid
President and Founder
Contract Manufacturing Consultants, Inc.
Robert Fried helps leading electronics OEM's develop world-class sourcing strategies for PCBA, cables, precision metals, plastics, modules and complete end-products. Other service areas are supplier risk assessment, comprehensive outsource ...
The SAC305 (96.5Sn/3.0Ag/0.5Cu) overwhelmingly consists of tin. The material that primarily creates the bond between lead free and leaded solder is Sn. So in your supplier's process, the material you are putting back on the BGAs is going to have a different percentage of Sn/Pb.
As the BGAs are being processed the percentage of Sn/Pb in the pot is changing. The volume of solder in the "pot" compared to the volume of solder on the BGAs is critical, because if all things were equal your new solder material would be 79.75% Sn, 18.5% Pb and 1.75% others. But they are not equal, because the solder bath volume is much higher than the combined volume of all the BGA balls.
If you are concerned, I recommend getting the balls (not the pot) material tested post processing to verify Sn/Pb + composition. I would test them at the end of the run, as the composition of the solder is changing during processing. Hope this helps.
Larry Harman
SMT Engineer
ACDi
Mr. Harman is an SMT Engineer at ACDi and worked at Oven Industries as a Manufacturing Engineer. H's worked at Philips manufacturing ultrasound probes/circuitry. He holds three patents, one for an ultrasound probe design, and two for innovative rat/mouse zapper circuits. He attended Pennsylvania State University for Electrical Engineering.
While a single dynamic wave can be used to remove lead-free BGA solder balls before the re-balling process, it is recommended to utilize a dual dynamic wave process to ensure that all lead-free solder is completely removed along with any organic residues, and that flux buildup and accumulation of gold are not transferred to the second pot.
The ANSI/GEIA-STD-0006 standard mandates that all automatic solder dipping apparatus and semi-automatic solder dipping apparatus shall use a dual solder pot system for this specific reason to avoid cross-contamination.
Carlos Bouras
General Manager
Nordson SELECT
What needs to be accomplished is the creation of a proper SN63 intermetallic. I would think that one pass will be sufficient if the wave has enough agitation to "scrub" the surface. Really the only way to tell for sure is cross sectioning and inspection of the intermetallic.
Kelly Atay, Sunstone Circuits
A couple of more things to think about...... The GEIA-STD-0006 does indicate using a dual pot system for aut0 as well as semi-auto machines use a dual solder pot system to avoid cross-contamination. I would ask the reballing supplier for objective evidence of them having verified the alloy in their wave recently. This method of stripping off solder balls while "hands off" has the danger of sending the die through another thermal excursion potentially reducing the reliability of the component. Do you really want to do this? Some type of end use environment reliability will confirm if this is is a risk of the reballed devices.
Bob Wettermann, BEST Inc
Essegi-Automation
The new Smart Rack Mobile
