Glenbrook Technologies
Viscom
Viscom
December 12, 2024 - Updated
July 20, 2017 - Originally Posted
How to Re-qualify BGA Spheres
What procedure would you recommend to "re-qualify" a lot of BGA spheres. We keep our spheres in a nitrogen cabinet, so I doubt that they would have degraded past the point of use. Any suggestions would be very helpful.
J.D.
I take it you mean for solderability. This can be done either with a wetting balance and using a low temperature alloy or by reflowing them to a known good coupon using only a sticky flux and cross sectioning to evaluate IMC thickness and formation.
Gerard O'Brien
I would do a solderability test and cross section of a standard assembly made with your standard process. If the spheres adequately wet the pads and the intermetallic is uniform and sufficiently thick, I would say that the spheres are still usable.
Kay Parker
Technical Support Engineer
The pertinent question to consider is, what physical processes do we expect might degrade performance of the spheres, and have we mitigated them effectively? So to answer the above, let's list the things that might occur in storage:
  1. Oxidation; you've effectively mitigated this by using nitrogen storage, which limits both the molecular oxygen from the atmosphere, and water, since nitrogen sources are normally very dry.
  2. Recrystallization; Sn and Sn alloys are above their recrystallization temperature at room temperature, so microstructure may evolve over time. This should not be an issue, since you are going to re-melt the spheres during use. It might only become an issue if the changes caused surface morphology changes that defeated optical inspection. Such changes would be apparent on visual inspection. Risk is very low indeed.
  3. IMC formation; not a problem, since the spheres are not in contact with any other metals.
  4. Organic contamination; potentially the spheres could accumulate organic material if packaging materials outgas and the outgassed products are re-deposited on the spheres. Whether said products would be detrimental is another question. Risk is low, but not zero, and nitrogen storage does not mitigate.
So based on the above, it seems like(1) and (3) are mitigated, and (2) can be dismissed with a quick visual inspection. That leaves (4). I'd suggest a quick, empirical solderability test. Use a clean, solderable surface much larger than the ball diameter, and a mild tacky flux, less active than you'd use for ball attach. Solder a sample of spheres using a profile at the minimum acceptable peak temperature. Check solder spread against a new lot, or failing availability of a new lot, just look for acceptable wetting angle at the periphery.
Recommend to perform Shear / Bend Test on entire PCBA to determine the Solder Strength on BGAs. Upon Shear test a Dye-and-Pry test need to be carried out on BGAs to know the Shear / Bend test results. It should identify any cracks or separations within the solder joints. This test is traditionally performed to evaluate the solder joints of BGA components, as their joints are not readily visible. Additional to that, you can perform,
  • Micro sectioning on BGAs: The joints should be examined for voiding, cracking, wetting, and a variety of other features and anomalies, via Optical Microscopy. Once sectioned, the joints should also be examined at high magnification via Scanning Electron Microscopy / Energy Dispersive X-ray Spectroscopy.
  • PUSH TEST Analysis: Push Test on BGAs
  • Pull TEST Analysis: Pull Test on BGAs
Swaroop Pawar
PCBA Industrialization
Schneider Electric
Have 18 years of experience in electronic Industrialization. Specialties in PCB Design & manufacturing process, PCBA Process Development and Continuous Improvement.
Some manufacturers assign a shelf life on 1-2 years to their spheres. One way to re-qualify is by performing a solderabilty test preparing a BGA component and soldering onto a test coupon. If more reliability data is required you may perform a cross-sectional cut to analyze ball composition & integrity.
Edithel Marietti
Senior Manufacturing Engineer
Northrop Grumman
High-Density Rigid PCB Boards
