October 25, 2024 - Updated May 3, 2017 - Originally Posted Requirements for Installing Leaded vs. Lead-free Press Fit ConnectorsIs there a difference between the requirements to install a leaded press fit connector, and a lead free press fit connector? A.A. |
There is no difference. It all depends on connector size and the number of pins. However, there might be a slight difference on the pressure to be applied depending on the PCB surface finish.
There is not difference in mechanical strength, when mounted onto the PCB, most press fit connectors are RoSH compliant, meaning these connectors will be suitable for both, lead and lead free processes. If you are using a lead spec press fit connector, please check the part datasheet, for the following: Metal used on pins. Reflow maximum temperature.(typically this are 265 degrees celsius, for 5 to 10 seconds.
Yes there are different requirements between a leaded press fit connector, and a lead free press fit connector. Check with the manufacturer on the solder-ability of the connector. It might have plating on it that is more suitable for pressing than soldering. Specifically, you need to know for lead/lead-free soldering incompatibilities with said plating before utilizing. Also, the plastic used might not stand up to either lead/lead free soldering temperatures. Even if you can solder it, you might want to make "some" of the pins press-fit if only to hold the connector in place while you solder it. If only certain holes are press-fit then flexing and insertion force will be much more manageable. Note, there is probably information on the manufacturers' web sites that addresses these issues with more detail than I can give you. Check for application notes and white papers. If you are doing volume production then call your mfg. rep or distributor for help.
