Test-Research-Inc.
Test Research, Inc.
February 12, 2025 - Updated
January 24, 2017 - Originally Posted
What Is Causing Slanted Pins After Reflow
I am running small, thin PCBs mounted with pogo pins. After reflow some pogo pins are slanted.
What should I do to prevent this. My stencil thickness 5 mils.
J.A.
Due to the rheology of solder paste and density of the component you might experience the pogo pin to float during reflow causing some pogos to become slanted. Try the following:
First, decrease the amount of solder paste deposited by decreasing pad aperture, workmanship standards could be affected if aperture is decreased too much.
Second, if your SMD placement machine can be adjusted, increase placement force to secure component into the solder paste. Third, design a small tooling to keep pogos straight during reflow.
Edithel Marietti
Senior Manufacturing Engineer
Northrop Grumman
The Pogo pins appear to be surface mounted and once the solder reflows and expands the components or pins will float on the molten solder.
To keep the pins aligned I would suggest a template or fixture to hold the pins in place. If the pins were mounted into a fixture upside down, the paste could be screen onto the bottoms of the pins and the board could be aligned and placed over the pins and then processed through a reflow over to make the connection to the board. Once reflowed and the solder has solidified, then the fixture board could be removed and all the pins would be in alignment.
The intent is to secure the pins prior to reflow.
It sounds like the thin PCB is bowing slightly during reflow. Have them check to see if the pins bowing are in the same area/pins.
A reflow fixture should help in eliminating this problem.
Robert Freid
President and Founder
Contract Manufacturing Consultants, Inc.
Robert Fried helps leading electronics OEM's develop world-class sourcing strategies for PCBA, cables, precision metals, plastics, modules and complete end-products. Other service areas are supplier risk assessment, comprehensive outsource ...
If you have a mating connector, it is quite possible you can pull the mating sockets out and use the empty mating connector body as a reflow fixture (a pin holder) to hold the pins in place, or at least to use as a drill guide to make a mating connector using standard FR-4 material.
Whatever you use as an alignment fixture should make contact with the PWB, but just perhaps in one spot on each end and one spot on each side to ensure the pins are as perpendicular to the surface as possible. This may be all that is needed to hold them perpendicular.
If there is no danger of either the mating connector or the board pins reflowing together, (gold on gold), then I would think a mating connector that can take the reflow temperatures would make a perfect alignment tool, as it would provide a snug fit.
The way to do it then would be to place the pins into the mating connector and turn the whole thing upside down and place all of the pins into the board and just leave the mating connector on until after reflow. If all of the pins are pushed all the way down into the mating tool, then they should be perfectly aligned. However, they will be perfectly aligned with respect only to the surface of the small, thin PWB.
If the board is undergoing serious warping during reflow, then all of the pins will be slanted. However, the fix for that is to glue a thin piece of FR-4 material on the back side. This may or may not keep the PWB flat through reflow.
Richard D. Stadem
Advanced Engineer/Scientist
General Dynamics
From the photo, it appears that you have convex solder fillets. I was able to resolve a similar issue by increasing the diameter of the PCB pads and adjusting the size of the stencil apertures.
You need just enough solder to form a sufficient fillet at the base of the pin. Given a large enough PCB pad surface, the extra solder will wet outwards leaving a concave fillet and just enough solder underneath the part to form the intermetallic layer.
Rick Kompelien, Benchmark Electronics, Inc.
This is a PCB design issue - increasing the pad size will allow for proper formation of solder fillets. If you can't get the PCB design changed, you could try reducing the solder volume with a thinner stencil or smaller apertures.
Rick Kompelien
Principal Product Engineer
30+ years of experience working with electronic and electro-mechanical manufacturing and design (medical, automotive, military, computer, and industrial controls). Military veteran - served as a Combat Engineer with the United States Marine Corps.
