July 10, 2020 - Updated October 19, 2016 - Originally Posted What Is This Contamination?These images are from a failed position-sensor in our power plant. It is potted with some kind of epoxy-compound because of vibration-issues. We don't think the potting is done by the manufacturer, it is more likely done later in the assembly-line because it's done only for us.
What do you think? What are we seeing here? This sensor failed after only 2-3 years of operation among with several others. M.K. |
Need to know the surface finish on the PWB.
Looking at the images gives me several ideas as to what happened:
There is almost definitely corrosion going on, so the question is what is the source? From what we can see, it is limited to certain terminals, so my working hypothesis would be assembly soils that were not removed and later created an ionic path between terminals where a voltage gradient exists. The ionic path and moisture permeating the potting compound then combined with the voltage difference to drive corrosion of the terminals. This theory plays well with your hypothesis that the potting is being done at a post-assembly step. If the potting is done at a different location/organization than the assembly, they may not understand what soils are present, e.g. flux residues, and may not be taking the proper steps to ensure reliability.
From the picture, it is difficult to be sure. I would suggest there is a corrosive contaminant under the epoxy coating, likely left-over residue from a so called "no clean" flux. Before the Epoxy coating is applied, the assembly must be cleaned no matter what type of solder flux used. Such corrosion can also be caused by other contamination left behind by the assembly process, even finger prints.
The pictures are difficult to zoom into but it appears there is corrosion occurring. Is there a no clean flux on these circuit boards? If so that could be a potential source for corrosion, especially when the device is in operation. Potting material does not necessarily stop corrosion or electro migration from occurring. It likely slows the process enabling the device to operate over a longer period of time before failure.
The images from a failed position-sensor used in your power plant, appear to be potted or staked with some kind of epoxy-compound because of end application vibration-issues. You don't think the potting is done by the manufacturer, it is more likely done later in the assembly-line because it's done only for you. This sensor failed after only 2-3 years of operation. How long do known good assemblies last for comparison? Typically, when I encounter contamination of circuit card assemblies I recommend comparing a known good verses bad and extracting several samples for different locations to submit for FTIR, SEM/EDX, and IC analysis testing. The FTIR in my humble opinion will be the fastest and the cheapest for organics ( e.g., residual flux, adhesives , or coatings chemistry) that may result in subsequent contamination or corrosion failures. The SEM/EDX allows me to determine the inorganics involved ( e.g., Metals) that do not contain carbon. They have high melting points and particular high or low electrical conductivity properties. Inorganic substances are used in many applications and in various fields.. Often, they are used as coatings, catalysts, medicines, pigments and fuels. Finally, I would submit the known good verses bad circuit card assemblies for IC testing to identify Ionics per IPC-TM-650-2.3.28. IC testing will reveal anions and cations involved and specific levels critical to board assembly cleanliness. When certain levels are exceeded and exposed to moisture , bias, and temperatures subsequent contamination or corrosion failures result. After doing this analysis you will be able to determine if the failure is a result of supplier issues( e.g., Flux, adhesive, coating), Manufacturing(e.g., process problem) , Design ( e.g., pitch issues) , or end application ( e.g., harsh environment ).
Very difficult to determine the cause from the pictures provided, however there appears to be a conformal coat or potting present on the board. From the bubbles between the leads on the IC it looks to be the original application. I am guessing you are seeing 1 of 2 items, either poor rework was performed prior to conformal coat during the manufacturing process or there is a net in board getting hot. I would need to look at this under a scope to really determine what is going on. I am leaning toward rework during the manufacturing process and flux was not removed prior to potting.
Without further investigation, I can only guess this board suffered a short. Most likely from an insufficient cleaning process and possibly dendrite growth. It is very possible flux residue was left behind which may past initial testing but fail later in the field.
This looks like some form of corrosion. Most likely this was cause by flux residues beneath the coating. Any applied coating to prevent environmental conditions from affecting the product are not impervious to the absorption of moisture. Hence, if the unit has been in the field for two years, then the operating environment may be the source of the mechanism for the corrosion on the product. My recommendations would be to have the material analyzed to determine the exact material composition, which can then be evaluated as to its source and control of such.
Looks likely you have some corrosive residue left in the via and leaching out, causing the corrosion and subsequent failure. Is this on the power part of the PCB? I would suspect something pretty active (Hydrochloric/Hydrobromic Acid) especially if the finish of the PCB is HASL and it won't matter if its coated or not it will still corrode and sometimes faster with the coating on.
In looking at the photos below, I would suspect that the contamination is actually corrosion. We see this quite frequently.
General Manager Trace Laboratories Renee has been with Trace and an IPC member for 16 years. She has managed all military and commercial PB qualification and conformance testing and training, as well as product qualification and testing in the areas of solder pastes, fluxes, solder masks, and conformal coat. She is the chairman of the IPC Testing and the IPC-J-STD-004 Flux Specification Committees and the Vice Chairman of the Assembly and Joining Committee. She has published more than a dozen papers and presented at numerous electronics conferences.
With not a lot of data here are few things that I can think about - this can be some sort of oxidation caused by contamination in the assembly process:
Agreed, from the photos it looks like white flux residue on the boards. White residue is usually (but not always) salts, which are the “activators” in the fluxes. When these salts meet heat or other chemicals, white residue can result. This residue can corrode delicate circuits. There are many possible sources for the residue. The boards, the cleaning fluids and fluxes used, the cleaning processes, the way the fluxes and solder paste are stored, and even the weather. It is very hard to determine precisely what might be causing the problem.
Sheri Pear, Micro Care
There are three likely places to look: the contamination, the cleaning fluid, and then the process. 1. Look for a change in what you’re trying to clean. For example, have you just switched to lead-free? Or, did a spool of RMA solder get slipped into a “no clean” process? These material changes can cause unexpected residue and cleaning problems. 2. Check for a mismatch between the cleaner and the contamination. If the residue is an even, smooth layer of white film across a large area this usually indicates you have the wrong cleaner. 3. Review the cleaning process. Look for streaks or spots of white residues. These are the indicators of improper cleaning technique. |
