Ask the Experts | ||||||||
May 6, 2024 - Updated April 20, 2016 - Originally Posted Solder Splashing During Wave SolderingWe are experiencing solder splash during wave soldering while using both adjustable and dedicated pallets resulting in the splash on the boards creating ICT failures. The solder splash is popping up from the solder flow. What is the likely reason for this? C.V. |
Have you confirmed the preheat profile is meeting the flux suppliers recommendations? If using a VOC free flux, it is critical to ensure that the board is "dry" prior to it coming into contact with the wave otherwise the wet flux can cause spitting that could result in the issues you are seeing.
From the information given, two potential causes need to be ruled out.
There are a couple of issues to look at regarding the solder splashing up onto the bottom side of the board during the wave soldering process.
Hope this helps and if more is needed please let me know.
Solder splashes during waver soldering are often caused by the application of excessive flux, and/or inadequate preheat. The volatile materials used in fluxes, typically solvents, will explosively vaporize upon contact with the solder wave. This causes solder splashes. If too much flux is applied then the preheat will not be able to drive off all of the volatile materials. If the preheat temperatures are too low or the dwell time too short, then again some volatile materials will be left on the circuit boards. We recommend that the flux application rate be set to meet the manufacturers specifications. The pre-heat settings should also be set to meet the flux manufacturers specifications. In this case the amount of applied flux should be reduced, or the pre-heat time or temperature increased.
Without further information it's hard to say but could be flux left on the PCB while going through the wave especially if sizzling occurs or the Pump Pressures could be too high forcing solder through the vias and holes too strongly causing splashing on top side.
Your questions does not outline if the splash places solder on the top or the bottom of the assembly. Regardless, under most circumstances this is caused by some type of turbulence in the wave area. If the solder is being splashed onto the top of the assembly, I would look at the waves as they transition from either stand-by mode to run mode or from off mode to run mode. Standby would be used with a system that has a tracking system that activates the waves. Make sure that when the flush of solder leaves the wave hardware area and returns to the solder pot you don't see excessive splashing upwards. If splashing solder on to the bottom of the assembly, I would confirm it's a splash and not exhausted flux that has been over heated or over exposed to the wave dwell which is often confused as a splash as the solder will stick to the mask. If you can confirm it is a splash, look at the solder level in the pot and make sure you are at the right solder level.
Potentially insufficient preheat not drying the flux before the wave. More common with a VOC-Free flux. If not the flux, then possibly another source of moisture.
This is going to be a large work volume project. I would recommend to check the following:
Submit A Comment | ||||||||
