December 8, 2015 - Updated December 2, 2015 - Originally Posted Questions Regarding Underfill OptionsWe are being asked to apply a thermal compound layer of underfill under a SMT chip. Is there a standard that provides guidelines for too much, not enough, etc? If there is a hole on the secondary side of a CCA to apply this coating, what are some possible methods? R.W. |
I would refer you the underfill manufacturer for their recommendations.
There is IPC J-STD-030 Guideline for Selection and Application of Underfill Material for Flip Chip and other Micropackages. It provides all the information you need for your underfill process. To answer your second question; in all underfill methods I've worked with, the underfill was always applied from the top using automated equipment or directly onto the package prior to placement.
It's a bit difficult to answer this question without knowing all the applications details.
Dr. Hanzhuang Liang, Nordson ASYMTEK
In a capillary underfill process, the fluid is typically dispensed along one edge of the chip so that the fluid is pulled under the component. Whether you dispense too much or too little depends on the gap underneath the die. You also need to consider how much fluid needs to remain along the edge and what the keep-out zone should be around the die. You should see fluid on the other side of the die. There are a lot of papers that discuss how to calculate the optimal amount of fluid under the chip. In other underfill processes, high pressure can be used to drive fluid under the die. The fluid type typically used is a molding compound. If the fluid must be applied through a hole in the shield, there are several techniques that can be used, but depend upon the specific requirements and geometries of the part on hand. Contact me if you want to discuss this further. |
