August 25, 2015 - Updated August 19, 2015 - Originally Posted Max Peak Topside Reflow TemperatureIPC-7095C 6.4.2 discusses the maximum peak topside board temperature for BGAs to be 150C during tin/lead wave solder. Does anyone know how this temperature was determined? Are there supporting research papers or other IPC standards with more information? In the figure 6-25 there is a peak temperature listed for fine pitched components of 160C. Is there another standard that goes into this in more detail? S.M. |
Dusting off the memory cells, I believe the maximum 150C topside board temperature relates to the nominal glass transition temperature of FR4. References may include IPC TM-650 or NEMA. This temperature was established prior to the implementation of lead-free soldering and the use of laminates accommodating higher temperatures.
S.M. should check J-STD-020D, section 4, tables 4-1 and 4-1.
