June 6, 2024 - Updated March 18, 2015 - Originally Posted Hot Air Soldering for 0201s and 01005sWe are struggling to solder and rework small parts - 0201s and 01005s. I have been using a small nozzle hot air solder rework station with adjustable air flow. The minimum air flow on the unit will blow small parts across ... T.G. |
There are several companies that offer mini and micro soldering/de-soldering tweezers just for this type of work. I recommend checking with your soldering tip supplier to see if they can fit your current equipment.
I would suggest you rework with an IR rework station and dispense paste with a syringe. Check out the DAGE 3000. That what I have used for 0201s with some minor modifications you can place and reflow all with one system.
For these type of devices we have switched back to using infrared rework station. It is slow but works amazingly. Also see if your team can use a solder iron tweezer. I have not been able to successfully solder 01005s with this, due to the design of our lands. (Changed to almost bottom solder device to eliminate tomb-stoning)
Thank you for the question. I understand your frustration in using hot air to reflow those small components 0201 and 01005, as the processes are not quite in place to reflow components so small. Additionally the amount of paste to be applied to those pads is very difficult to maintain a minimum amount. The existing equipment has to be special to do this correctly and unless you can help from an equipment supplier it will be difficult. We are developing a process to do this and I would recommend visiting our website, www.eptac.com for more information.
In order to rework small/special components, you need special tools. From your question, I do not understand if you are reworking boards and these parts are close to the rework area or your intention is to rework these particular parts. If you want to rework parts like 0201 and 01005 I highly recommend the JBS nano station tweezers. They are great, I have used them in the past and they are the perfect solution for something like this. For stencil design, paste deposition, pick and place and reflow there are more things to consider. Should these components be in an area that gets reworked, you can minimize the damage by protecting the surrounding areas of the component being reworked from the hot air flow using masking or kapton tape.
Contact me at georgiansimion@yahoo.com. Rather than investing in a new machine, also consider inducing N2 if you are using a convection rework system. When the solder reflows an oxide layer will form around the solder causing a surface tension struggle with the vacuum from the machine. Using an IR system does not allow this function, so you stand to be successful using convection. Small passives mean the vacuum hole diameter needs to be quite small. The volume of vacuum often is not enough without inducing N2 to prevent the oxidation. Feel free to give us a call, we are reworking the smallest SMT devices without any issues. As small as 008-005 devices.
Sales Director Finetech Neil O'Brien has worked in the field of electronic manufacturing equipment for over fifteen years and is currently Sales Director for Finetech, a manufacturer of precision rework systems and die bonders.
