Start Micro Dispensing Today
July 3, 2024 - Updated
March 3, 2015 - Originally Posted
PCBA Inspection Process Causing Damage
We inspect PCBAs on a relatively hard ESD mat surface. QA claims that during inspection, moving of the PCBAs on the mat will scratch and stress the soldered components (bottom side).
Are there any studies on this matter?
Are there any dedicated tools in the market designed for this purpose?
T.S.
I am not aware of any specific studies that were done on the movement of a PCB on a"relatively" hard mat causing damage to bottom side components. It stands to reason that the use of a mat, properly grounded, is a benefit to the board. Typically any mat being used will have a softer surface than the laminated work surface of the bench.
If your operators are sliding the PCB across the surface then, yes, there is a potential for damage. Just placing a PCB on the surface should not cause any issues. If you have concerns about damage I would suggest switching to a homogeneous vinyl material which is typically a softer surface.
Be aware that this type of material cannot be used with a constant monitoring system as there is no conductive layer.
Jerry Karp
JSK Associates
True .Moving the PCBA on a hard surface will sometimes scratch components, and stress soldered joints. There are many table-top inspection stations on the market designed to avoid damage to the assemblies.
The common setup is a stationary rail that holds the PCBA. Other most advanced fixtures come equipped with a camera in order to display the images on a monitor.
Edithel Marietti
Senior Manufacturing Engineer
Northrop Grumman
I'd agree that any time we slide a PCBA across a surface, there is some risk. If the surface is clean and smooth, that risk is absolutely minimal unless very sensitive components are involved.
If your QA folks can provide quantifiable evidence that there is a risk, then one approach would be to use a carrier to which the PCBA is affixed and inspect while in the carrier. In this way, all contact with the bench is eliminated.
Another benefit is that the PCBA can beheld precisely level and at a known height, which might be important if you are inspecting under stereo microscopes. I'm envisioning an adjustable metal frame with feet to support the board off the table.
Touchless Solder Ball Removal
