March 7, 2024 - Updated December 3, 2014 - Originally Posted Cleanliness Standards for Electronic ComponentsI work as a supplier engineer in our automotive division and we are very concerned about cleanliness for electronic components. We have a very stringent humidity and temp test from one of our OEM's that causes dendrites almost every time we run the test. I have been looking for cleanliness standards for electronic components but the only thing I have been able to find is for PWB cleanliness. To date I have not been able to find any standards regarding cleanliness specifications for ionics for electronic components specifically. Are there for electronic component cleanliness in the industry currently or are there plans to review cleanliness requirements for components? D.D. |
Component cleanliness is "sort of" covered within the JEDEC standards, but typically they will reference MIL-PRF-STDs for component cleanliness. Two JEDEC standards I can recommend you begin your search with are JEDEC STD 22-B102E, and JESD9B, specifically section 8.1 which uses the words "metallization" to cover any conductive condition, including under-etched metal, crystallization, dendrites,and so forth. Anyone can get the JEDEC standards by simply going to www.jedec.org and registering; it is free of charge. Also they are cheaper than sleeping pills, and more effective.
Try IPC/JEDEC J-STD-033,Handling, Packing, Shipping and Use of Moisture/Reflow Sensitive Surface Mount Devices,see image below, of IPC Standards,you should find what you are looking for under "Storage and Handling."
I have not seen any other document that provides specs for component cleanliness other than IPC but you are not the only one experiencing this phenomena. Dendrites will form when current & moisture are introduced to two adjacent conductors. Even distilled water can caused dendrites if the right conditions are met. You did not mention if these components are going to be conformal coated. You could avoid formation of dendrites if you provide a conformal coat to the components or area surrounding them.
From a humidity standpoint, the dewing test is a difficult one. As a materials company who supplies solder paste to automotive applications where the no-clean residue is not cleaned off post-reflow, we have pastes that pass the BMW dewing test. From a temperature standpoint, we have seen instances of dendritic growth under flat-bottom components for dry heat testing (120 deg C for 21 days). The ionics and residue characteristics of the solder paste can be engineered to address this issue.
There are no present standards for how clean a component has to be to have long term reliability, either in IPC or IEC. There are some standards for how clean assemblies need to be, but those standards are presently being updated and the old standards are being obsoleted. Ion Chromatography is the tool of choice for determining component cleanliness.
Currently there is one standard that is applied for electronic piece parts and it is the GEIA-STD-006 post solder dip to replace final finish.
Joe Russeau, Precision Analytical Laboratory, Inc.
It utilizes the Resistivity of Solvent Extract (aka ROSE) test, which is an improper application of that technique IMHO. There are no IPC derived requirements or methods for component cleanliness at this time. However, as I am the IPC chairman for the Ionic Conductivity Task Group I would encourage you and others to come to our meeting in the Fall at SMTAi to throw out some idea's. The IPC is the best source for standards for our industry, Electronics Assembly. In your case, a standard for cleanliness, the IPC/EIA J-STD-001, "Requirement for Solder Electrical and Electronic Assemblies" has your answer in section 8, "Cleaning Process Requirements." If you do not have a copy of this standard, please go to the IPC's site and buy one. This helps support the great people who produce these standards. How clean electronic components and assemblies must be is up to your customer and you should seek their input on what they require first. Some high impedance circuitry requires extreme cleanliness and others have no real concern. The IPC/EIA J-STD-001 section 8 outlines a "Cleanliness Designator" beginning with the letter "C-" and two digits that follow. This is a standard way for your customer to specify what to clean and to what extent they want you to test to prove cleanliness. As I read the standard, section 8 indicates that "Assemblies shall be free of dirt, lint, solder splash, dross, wire clippings, etc." and "Unless specified by the user..." (your customer) all assemblies shall meet the default cleanliness designator "C-22" which means, "Both sides of assembly shall be cleaned" and a "Test for ionic residues required." The complete details of the Cleanliness Designator and the testing methods are outlined in the standard, section 8. Your customer needs to specify a cleanliness designator for you to follow or you must use the default designator C-22, if you intend to meet the requirements of the IPC/EIA J-STD-001 standard.
