May 2, 2024 - Updated October 21, 2014 - Originally Posted Hand Soldering at Low TemperatureWe often need to make repairs in the field involving circuit board soldering. Is there any impact on a hand soldered circuit boards during winter where the circuit board and atmosphere are at 0 degrees C and humidity at 10%? P.S. |
As long as you get the temperature up to the melting point and keep it there while the solder/flux does its job, you should be fine. The main concern I would have is that the solder joint would most likely cool extremely rapidly and that could cause some issues. I would find a way to warm the area as much as possible during any repairs and do a very thorough job inspecting any solder joints created in that environment.
Kind of provides a new definition of cold solder joint. Two things would concern me with these conditions, thermal shock, and ESD due to the low humidity conditions. Any preheat that can be applied would help in the reducing the thermal shock to the component and the board. A larger mass soldering tool may be necessary to certify enough thermal energy is provided to the joint being worked upon. As for the ESD, verify proper grounding is sufficient to not destroy the component. I would also suggest an alternative option is to have enough spare parts so the fix can be taken care of by switching the product, then sending the defective product to the repair center for corrective action. I'm sure there is more to this process than what I've covered, but these are the quick things to take care of in the repair of these boards.
First, let's look at the impact on the "delta-T," or the temperature difference between the board and the soldering tip. Most hand soldering operations are carried out with tip temperatures of at least 350°C. With our board initially at 0 degrees C, the delta-T is 350-0=350°C. If the board temperature is at "room temperature" of 20°C, the delta-T is 350-20=330°C. So the delta-T is increased by only 6%. Soldering time may be slightly longer to get good flow, but should not be impacted dramatically unless soldering is done without protection from strong wind. From this analysis, we would not expect the temperature difference alone to be problematic. There is one other consideration, however. The moisture content of the circuit board may be of concern if the board has been exposed to high humidity for a long period of time, and if the PWB material and/or construction make it susceptible to high moisture uptake. Laminate materials like polyimides are especially susceptible. Thicker boards with higher layer counts are more susceptible to damage as well. You would need to determine the level of susceptibility for your specific boards, so it is not possible to say whether moisture is an issue.
Anytime you are soldering a PWB there is a risk to both the parts and the circuit card. A lot would depend on the material and the components. Can I get some additional info such as material, layers, 10% humidity is not to bad but most material absorb moisture quickly and maintain it. Concerns would be excessive heat causing measling, or internal delamination.
Electronics Engineer Corporate PWB BDE Boeing Research and Development 35 years in the electronics industry in design and fabrication of rigid, rigid flex and flexible pwbs. Corporate SME (DBE)on pwb design, fab and assembly.
