Plasma Etch
January 26, 2024 - Updated
October 8, 2014 - Originally Posted
Exposed Copper Risk
Exposed Copper Risk
We received many PCB's where a modification have been completed. The modification involved soldering a chip cap to an existing pad and adjacent surface ground layer. The modification is correct, but no coating have been applied to the stripped area.
This PCB is used in an outside environment exposed to high humidity and temperatures extremes. Should we be concerned with corrosion? What should we do?
A.H.
I would not recommend leaving exposed copper in ANY environment. There are a couple of ways to deal with this issue:
  • Since this appears to be a very small area, I would recommend using a solder mask touch up pen to cover just that area.
  • A conformal coating would also work but would probably have to be applied with a small brush to the exposed copper.
  • That area could be sprayed with an aerosol conformal coat. This will eliminate the exposed copper, but is much more difficult to control and you may cover areas where you do not want it.
Mark Finstad
Senior Applications Engineer
Flexible Circuit Technologies
Mark Finstad has over 30 years in the flex circuit industry in both design and manufacturing. He is a regular speaker at IPC APEX (Professional development courses) and PCB West (flex circuit design courses). He is also vice chair of IPC-2223 and active member of IPC-6013. Finstad has extensive experience with both domestic and off-shore manufacturing.
The copper will be more susceptible to oxidization, but will likely not cause too much more of a risk for corrosion. However, coating it epoxy or masking is easy, cheap and will rule out any corrosion or other issues.
T.J. Hughes
Manufacturing Engineer
Mr. Hughes has been in the electronics manufacturing field for 20 years. Operating the processes and as a manufacturing engineer for the last 14 years. He is also a CIT as well as an SMTA Certified Process Engineer.
I would suggest you purchase some solder mask touch up pens and simply touch in the areas of exposed Copper. This should be more than sufficient.
If you cannot purchase these then a light coat on the area of conformal coating will be sufficient, but get one with a UV light trace so you can double check it is covered.
Greg York
Technical Sales Manager
BLT Circuit Services Ltd
The exposure copper adjacent the surface ground layer has the potential for corrosion from ionic contamination and environmental effects. Halide ions, notably chloride and bromide ions can penetrate areas of the copper surface. When the copper pad is exposed to environmental effects, tiny pits can form on the copper surface.
The oxidation of the copper enables pitting and crevice corrosion. To mitigate these corrosion potentials, I recommend that the exposed copper be cleaned post soldering and then coated to prevent environmental exposure.
Mike Bixenman
CTO
Kyzen Corp.
The exposed copper is definitely a problem for outdoor environment and humidity.The copper is likely to corrode and eaten away due to corrosion. The corrosion product (salt) produced could form acid with excess moisture and lower insulation resistance, between tracks nearby.
One type of correction can be applying conformal coating (Polyurethane- preferred) selectively to exposed area that can provide some protection from corrosion. Exposed copper definitely does not meet IPC-A-610E requirements.
KN Murli
Head-Quality
Absolutely. Bare copper? Ever leave a penny outside? Green in no time. Either go with conformal coating for the entire board, my suggestion, or localized conformal coating for the reworked area.
You indicate that the PCB is used "in an outside environment exposed to high humidity and temperatures extremes. Should we be concerned with corrosion?" If your product is currently not protected from these harsh environmental conditions are you not already seeing failures? A PCB used in those condition should be completed encased in a quality conformal coating.
Jerry Karp
JSK Associates
Yes you should be concerned if you expect your product to be in the filed longer than 18 months, and if your product is exposed to humidity and temperatures.
You would need to confirm that all off you pre manufacturing process such as wave soldering and hand soldering are RoHS compliant. Non RoHS compliant products such as fluxes, contain acids such as chlorine or bromine. This is corrosive after the soldering operation and would cause corrosion of the surface during operation of the product.
Many cleaning and testing methods were developed to clean the surfaces and to test to insure the surfaces were noncorrosive afterwards. The majority of these test methods involved checking for ionic contamination after the cleaning was performed. A passing product would have a low level of ionic contamination. (I strongly recommend that you do this test, to confirm that the products used on your PCB are RoHS compliant.)
RoHS compliant products, such as "no-clean" fluxes compose of organic acids such as a dipic acid or citric acids. These organic acids are decomposed by the temperatures reached during soldering, and are likely to have very slow or low corrosive effects.
I recommend that you make use of a solder mask pen, which will offer a solder mask coating over your exposed copper. This is the safest, and most cost effective way to resolve your problem.
Kishan Sarjoo
Process Engineering Manager - Electronics
Altech UEC, South Africa
Currently with Altech UEC and responsible for technology road map in PCBA electronic manufacturing and technical support for PCBA electronic manufacturing for Altech UEC and its JDM's. Over 7 years in SMT, Radial Insertion, Wave solder & Test Applications.
Yes!
Mahendra Gandhi
SME - PWB Technologies
Northrop Grumman
Mahendra Gandhi has been working in interconnect industry since 1972.
Ina word, yes, you should be concerned. The level of risk really depends on the enclosure and operating environment. If the product will continually produce enough heat to keep it above dew point, the risk will be substantially lower.If the product does not operate continuously, however, then the risk is higher.
Another issue is the levels of ionic materials in the end use environment. If, for instance, the product might be used where salt is present, e.g. near the ocean,the corrosion risk is greater. The exposed copper will always represent a greater corrosion risk than the solder, however there is a corrosion risk for both. Conformal coating can help to protect against moderate amounts of moisture. It will not protect against gross amounts of liquid, however.
Yes, you do have a potential corrosion issue. You may use conformal coating to spray on the exposed copper on the populated board and change to different surface finish, such as HASL, in the future.
David Bao
Metallic Resources, Inc
If the Printed Wired Boards (PWB) need to work under humid conditions esp. for high reliability applications, I would suggest to have a protective coating, to protect from various ionic contaminants as well as the exposed copper getting oxidized.
The following procedure may be followed:
  1. Clean the PWB with Isopropyl Alcohol and dry it.
  2. Apply solder mask with a touch up pen.
  3. Apply conformal coating - either Poly Urethane resin or Paraxylene (Parylene) and wait for curing.
Parylene is preferred to Poly Urethane due to its lower moisture permeability, ability to cover sharp edges & transitions and penetrate into PWB, pin holes and cracks.
Dr. KUTTIYIL THOMAS OOMMEN THARAKAN, VSSC
When soldering the end of the chip resistor to the exposed ground plane, simply flux and solder the exposed copper around the part at the same time. Then clean, dry, and touch-up the area with conformal coating. That way there is no possibility of exposed copper, coating or no coating.
Richard D. Stadem
Advanced Engineer/Scientist
General Dynamics
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
