Start Micro Dispensing Today
September 3, 2014 - Updated
August 26, 2014 - Originally Posted
V - Scoring PCB Question
I am considering scoring a PCB with a 90 degreescoring blade after SMT placement and reflow to create a card edge connector ona PCB. I would score deep enough to bevel and depanelize in 1 step. Is there a precedence for doing this? Are there any horror stories of failures?
B.S.
I'venot heard of anyone doing the scoring after SMT, though I’m sure it has beendone. I can’t think of any show stoppers... there are, however, some risks thatneed to be addressed. Here are the ones I can think of:
  • Support of the board needs to eliminate possibility of bendingstresses in the PWB that may damage components or joints near the edge. Thisshould not be a real issue because you will need very solid support in order tocontrol score depth
  • Damage to the metallization at the edge of the score maynecessitate a post-score inspection and burr removal. Blades need to betailored to avoid severe damage, e.g. lifting of the edge of the copper fromthe laminate
  • Conductive debris will be created by scoring through the metal,and this will need to be controlled/removed so that it does not result in anelectrical failure
  • Broken glass fibers resulting from breaking along the score linecould become a risk to contact reliability, and should be removed afterbreaking at the score.
You will generatepost-assembly dust that will include metal (copper) particulates. Otherwise,going sufficiently deep to depanel with a 90-degree cutter will produce amoderately wide bevel. Other issues depend on actual PCB substrate and v-scoreprocess control.
Robert "Bob" Lazzara
Circuit Connect, Inc.
Touchless Solder Ball Removal
