November 6, 2024 - Updated August 13, 2014 - Originally Posted Adhesion Problems with Conformal CoatingWe have a large RF back plane that is gold plated on the operational side. We are having intermittent adhesion issues with the conformal coating. Our vendor wants us to change to a new coating. We are being told that in general conformal coating has a very difficult time adhering to gold surfaces. And the cracks or lifting in the coating is caused by stress in the back plane where it is fastened to the card guides. What can we do to eliminate the adhesion problem? T.A. |
Goingto a Silicone based conformal coating could help with the cracking. As far as adhesion goes, making sure the surface is very, very clean is critical, as well as making sure the material you are using isn't expired, or mixed incorrectly.Is it possible to conformal coat it after the card guides are on? That may help as well.
To address the issue with the conformal coating adhering to large gold surfaces we would suggest using a plasma surface treatment to roughen up the surface to improve the bonding energy.
For your review and consideration: Plasma Treatment Improves Conformal Coating Adhesion from Nordson March
President Circuit Connect, Inc. Bob has been in PCB design and fabrication since 1976. He has held elected positions with the SMTA, is a member of the MSD Council, has served as a committee member for various IPC standards and is a Certified IPC Trainer.
