April 22, 2014 - Updated
April 16, 2014 - Originally Posted
Lead Emission for Selective Soldering
Is there a formula, process or tool we can use to measure the lead emission levels for our selective soldering machines? I understand the emissions are generally much less than a full wave soldering machine.
W.P.
Thereis no good way to calculate lead (Pb) particulate from your selective solderingprocess as there are far too many variables. It depends on the jetor wave temperature, solder jet or wave surface area, turbulence of liquidsolder, turbulence of air around the jetting or wave process, exhaust flow,exhaust flow turbulence, inert gas volume if there is inert gas in your process,solder alloy, even air temperature. These are just a few of thevariables. Open a door or window to the outside and everythingchanges. Ifyou have a steady-state process (controlled and repeatable conditions), thenyou can do some basic air sampling as with Draeger tubes or other environmentalmonitoring system and get estimates of Pb particulate in and around theselective soldering operation. There are many online guides to airsampling. This one has some basic guidelines: http://www.health.ny.gov/environmental/indoors/air/guidance.htm It is critically important that the process isexhausted and that the exhaust is sized appropriately. Ensure thatoperators are versed in the dangers of handling Pb or Pb-bearing alloys andalso aware of Pb-particulate environment. Also ensure that you are incompliance with State and Federal environmental statutes.
Gary Freedman
Colab Engineering
