Start Micro Dispensing Today
August 1, 2024 - Updated
April 2, 2014 - Originally Posted
Frequency of Checking Solder Paste Viscosity
Is it necessary to check viscosity of solder paste before each use? How often should we check and verify solder paste viscosity?
K.G.
It should not be necessary to check solder paste viscosity with the most modern formulations. Most will now last over several days at high heats and will require little refrigeration, if any at all.
If you are finding the contrary, it could be a good idea to look around for a new paste supplier.
Greg York
Technical Sales Manager
BLT Circuit Services Ltd
There are some issues that make checking viscosity less useful than it might be:
  • Differences in the equipment used (manufacturers usually use more sophisticated equipment than end users have available)
  • Differences in the test conditions (very tight control of all conditions is required)
  • Differences in test methods (even with the same equipment, minor differences in test protocol can create significant differences in results)
  • Viscosity changes during shelf life
Manufacturers' control of viscosity is typically much better than it was years ago (more modern flux formulations, better process control, lower powder oxide content), so there is less risk of out-of-spec material.
I strongly prefer performance-related tests, e.g. implementing in-line solder paste inspection (SPI), to monitor the paste printing process. If a problem is detected with a paste lot, lab techniques can then be used to investigate. SPI can also be used with a test stencil and substrate to do incoming validation of paste performance, but the paste sample size need to do so is rather large, and may not make sense for some users.
If the solder paste has been correctly shipped and stored then there should be no requirement to measure viscosity. If you wish to do so as part of incoming inspection then this would be the time to do so, rather than before use. Make sure that the storage and handling of your paste meets the manufacturers recommendations and you should have no problems.
If your paste has expired then it is best to scrap it as other things can change as well as viscosity. If you do decide to measure viscosity make sure you have the same equipment and test conditions as the manufacturer uses otherwise your data will not be comparable and you will have wasted your time.
Neil Poole
Senior Applications Chemist
Henkel Electronics
No, typically it is not necessary to check viscosity before each use. We check the viscosity of the paste (and other parameters) before it leaves our facility to ensure it meets our specifications. Since our pastes are formulated to operate over a wide viscosity range, it should not be necessary to check the viscosity provided it is stored/used per our guidelines.
These guidelines include cold storage,a sealed container and allowing the paste to reach room temperature before using it. It is also important to note that viscosity measurements are highly dependent on the type of equipment used and the sample so if you choose to measure viscosity, keep that in mind. Of course, if the paste looks'different' than normal, it is always prudent to ensure the material is still acceptable before starting a production run.
Brook Sandy
Technical Education Program Manager
IPC - Association Connecting Electronics Industries
As manager of IPC’s technical educational program, Sandy-Smith will be responsible for content development and successful execution of IPC’s educational programs and technical proceedings for conferences, webinars, workshops, tutorials and professional development offerings for the electronics industry. She will lead the development and execution of the technical program and professional development curriculum components of the organization’s trade show events, specialty conferences and professional development events.
Frequent checks of solder paste viscosity is not generally useful. Most pastes are thixotropic meaning that they paste shear-thin under the action of the print squeegee pressure and number of cycles.
Checking at the onset of the print run will yield a different viscosity value than after the paste is worked a while. Other factors that are critical to paste viscosity are dry-out (evaporation of solvents within the paste system), absorption of atmospheric moisture, plant temperature and relative humidity.
If a paste formulation gets too loose during printing with constant and appropriate environmental conditions, then I would suggest:
  • Reviewing idle time of the paste on the stencil (paste dry-out being a common issue)
  • Reviewing the volume of the paste on the stencil (apply too much and it will be more prone to dry-out)
  • Reviewing re-use of solder paste (paste scraped off of stencil at the end of a run to be used as again for a future run... not a great practice)
  • Paste storage conditions prior to use(proper storage temperature and proper warming)
  • Proper stirring of paste prior to use(avoid excessive ultrasonic mixing (known to cause thinning))
  • Contacting the paste manufacturer to find out why the paste is not printing properly Finding a suitable replacement paste that maintains a workable viscosity under typical plant conditions and line volumes
Gary Freedman
Colab Engineering
The solder paste users do not need to check the viscosity once it is qualified for their process. It is the responsibility of solder paste maker to make sure the viscosity is within specified range.
Solder pastes are designed to have thixotropic property, which means solder paste will be sheer thinned (decrease in viscosity) during the printing process and the viscosity will increase after the printing process.
The thixotropic property of the solder paste will insure a good release from stencil aperture and prevent the printed paste from cold slumping. A freshly opened jar of solder paste should be mixed lightly for several minutes prior to putting on stencil to ensure a good rolling under the squeegee.
David Bao
Metallic Resources, Inc
Touchless Solder Ball Removal
