Test-Research-Inc.
Test Research, Inc.
April 8, 2014 - Updated
April 2, 2014 - Originally Posted
Minimum Component Lead to Lead Spacing for Wave Soldering
What is the recommended minimum lead to lead spacing for through hole components run through a wave soldering system? Would the spacing be different for lead-fee solder compared to leaded solder?
V.P.
Theminimum practical pitch for multi-lead components such as connectors is about1.27mm (0.050”); I have not personally dealt with any with smaller pitches. Itis in theory possible to do smaller pitches, but the required hole diameter,and thus the maximum lead size, becomes very small. Pad sizes are also severelylimited, which will affect soldering performance. The small hole alsorepresents a problem for getting flux penetration and hole fill. The minimum pitch should not be different for Pb-free vs. SnPb. Ineither case, it is necessary to tightly control lead protrusion to reduceshorting risk. It is potentially more critical with Pb-free due to the highersolder surface tension.
