October 4, 2023 - Updated January 15, 2014 - Originally Posted Blow Holes and Disturbed JointsWe are finding many blow holes and disturbed joints after reflow. Our PCB is 1.7 mm thick and baked prior to reflow at 120 C for 6 hours. The process is non RoHS. Peak temp for reflow is 220 C. What could be going wrong? P.P. |
It is hard to diagnose a reflow problem without seeing a profile, but I would suspect that the heating rate during the early part of the profile is too high.
Manager, Process Technology BTU International Mr. Dimock is the manager of Process Technology at BTU International. His extensive experience in thermal processing includes positions at Corning, GE, and Sylvania. He has authored numerous articles on lead free processing and process control, taught classes at SMTAI, and participated in the IPC Reflow Oven Process Control Standard committee.
In the case of multilayer PCBs it is unlikely that moisture trapped deep within the boards will be fully released. Baking schemes such as yours are generally effective for latent moisture only around the PCB edges. Factors regarding moisture mitigation and elimination have been considered through committee at the IPC and include:
President Circuit Connect, Inc. Bob has been in PCB design and fabrication since 1976. He has held elected positions with the SMTA, is a member of the MSD Council, has served as a committee member for various IPC standards and is a Certified IPC Trainer.
Interesting question. It is not identified where and when the boards were baked, be it either prior to solder paste deposition and component installation or after the paste deposition and component placement. Also not included in the question is the paste type used,although it mentioned that it is a no RoHS paste, the thermal profile used and the type of reflow system used. Hence, with this lack of information I offer three concerns to be reviewed.
Have you verified the correct copper plating thickness by cross section?
This issue can be caused by a lot of parameters. I do not recommend to change them all but you can look at:
The root cause is the violation of the Time/Temperature ratio. Age old. There is not enough time at preheating temperature to drive out the solvents. Everything else branches out from there. Once the joint is at or past solidus the vapors are still outgassing hence the blow holes and joint distortion.
Ike Sedberry, ISEDS
