Plasma Etch
December 19, 2013 - Updated
December 11, 2013 - Originally Posted
Silkscreen as a Masking Layer?
Can silkscreen effectively be used as an additional mask layer? For instance, if a negative silkscreen image is used it would coat an entire board except where the printed reference designators are located. The possible benefits are increased electrical insulation and resistance to chemical and mechanical damage. Has anyone ever done this before?
J.M.
Becauseyou're re-purposing the material from Marking feature to Insulatorfunction, you might first check with UL (presuming the end-product performs toUL).
Robert "Bob" Lazzara
Circuit Connect, Inc.
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
