Nordson-ASYMTEK
A Lifespan of Reliability
Nordson Electronics Solutions makes reliable electronics an everyday reality. Selective soldering, dispensing, coating, and plasma solutions.
Circuitnet Advertising Delivers Results!
Vapor Phase Profiling
Thermal profiling the vapor phase soldering process – especially those with vacuum – is challenging. ECD's M-VP™ sealed barrier can take it. Learn more.
June 28, 2024 - Updated
November 19, 2013 - Originally Posted
Twisting Multi-strand Wires
Should multi-strand wires be twisted before they are tinned with solder? What are the benefits of twisting prior to tinning?
A.S.
Twisting wires after tinning can cause cracks to form exposing the base metal. This can promote oxidation and therefore solderability. It also adds internal stresses on the tinning and this increases the risk of tin whiskers potentially, especially with high tin alloys.
So in most cases, wires are twisted and tinned using no-clean fluxes or RMA low solids fluxes to avoid corrosion issues.
Peter Biocca
Kester
Most multi-stranded wires come twisted from the factory. If they are not twisted, it's possible that the wires were un-twisted when the wire was stripped. To answer your question directly, yes, the wires should be twisted before tinning.
According to the IPC-WHMA-A-620B, section 3.3, "Disturbed wire strands should be restored to approximate their original lay." It's also called out as a defect for a class 2 and 3 assembly if the general lay of the strands has not been maintained.
One word of caution, if you use bare hands to twist the wires back to their original lay, be sure to clean the wire well before attempting to tin.Your bare hands will leave oils and salts which will interfere with a good solder joint.
Kris Roberson
IPC
Multi storied wires should be restored to the original twist and should not be twisted beyond.
Tinning takes place through capillary action the solder moves up the strand. It is a good practice to use heat sink to prevent the solder getting into the insulation.
There should be un-tinned portion of at least 1 D where D is overall wire diameter to the end of the insulation.
The tinned portion of the wire becomes solid and un-tinned portion should provide the flexibility to give stress relief to prevent failures.
KN Murli
Head-Quality
No, twisting is generally not necessary. However, IPC-A-610 states, "Wire strands disturbed during insulation removal process should be restored to approximate the "original lay."
Richard Henrick
Quality Assurance/Regulatory Compliance Manager
Sanmina Corporation
Richard has 18 years experience in the medical electronics industry at both a contract manufacturer and OEM. His experience includes PWA and finished device manufacturing as a Manufacturing Engineer and during the past 7 years as plant Quality Assurance/Regulatory Compliance Manager. He holds 5 American Society for Quality Certifications and is a Certified IPC 610 Trainer.
To twist or not to twist? Looks like you should always "...restore the original lay..." before tinning per IPC standards as mentioned by several of the expert replies. An other question is why tin? If you are pre-tinning before soldering into a thru-hole in a board, it is not really needed, the solder process will tin and solder it just fine. If prior to crimping or installing into a screw tightened connector, I do not recommend tinning. Solder is soft and will yield under pressure, relaxing the previously tight connection and become loose. Best to use ferrules to capture the strands before installing into/under a screw tightened terminal/lug.
Paul Austen
Senior Project Engineer
Touchless Solder Ball Removal
Viscom
