Glenbrook Technologies
Viscom
Viscom
October 2, 2013 - Updated
September 23, 2013 - Originally Posted
Octagonal Pads for 0402 Chip Caps
One of our chip vendors has recommended using octagonal pads for 0402 decoupling capacitors that reside under a 1mm-pich BGA. Is this common practice? Are there any standards that addresses this?
J.M.
This type of design though not being evaluated bycomponent manufacturer either BGA/0402 but there's patent exists for same andyou can opt to try this in sample evaluation. you may google patent- US20080205011
Subrat Prajapati
Supplier Quality Leader
Ge Healthcare
Ihave not seen this exact strategy, but it does make sense. The octagonalpattern (effectively a square with the corners cut off) provides addedclearance, vs. a square, between the lands and non-common pads while minimizingthe impact on the printing, placement and reflow processes. It'swell documented that there is only moderate difference in printingeffectiveness between a square and a round aperture of the same dimension, andthe octagon is a "compromise" between the two. In fact, it can be shownmathematically the area ratio is exactly the same for a square, a roundaperture or an octagon of a given dimension! The placement process should not care whether the paste deposit isrectangular or octagonal, as long as the size and spacing is correct. Thereflow process should be similarly agnostic as to shape. More important is thethermal gradient due to the interconnections with the vias. The sides of thelands attached to the (large) traces connected to the via lands will be coolerthan the opposite sides, and as a result you may see shifting of the chipsduring reflow. The traces are quite large, and I'm not sure why they need tobe. The effect is that nearly half of the 0402 land becomes "solder maskdefined" so if the solder mask shifts relative to the metallization, the landcan grow or shrink. This effect can be minimized by reducing the trace width.You do have to be careful to maintain adequate mask web thickness to preventsolder from the 0402 from flowing down the via. A reasonable minimum is 0.003"
High-Density Rigid PCB Boards
