January 16, 2024 - Updated May 29, 2013 - Originally Posted Solder Balls During Selective SolderingWhen selective soldering the secondary side, we are producing solder balls on the primary side. We are also reflowing surface mount components on the primary side. What can be done to prevent this from happening? C.W. |
Solder balls on the top side during selective soldering could indicate the preheating of the liquid flux is not sufficient.If solvent remains after the preheating zone, it could lead to explosive removal of the solvent. This outgassing would bring with it some solder to the top-side which will form solderballs. Removing solvents being IPA with the alcohol based fluxes or water in VOC-free fluxes is critical to avoid solder balls but also other issues such as insufficient hole-fill or bridges. The solder heat should be working the activators and not vaporizing flux carrier solvents. Alcohol based fluxes tend to dry up more readily during the preheat time and are preferred. Applying the least amount of flux to insure adequate wetting without solvent entrapment is also beneficial. Senior Market Development Engineer Kester Mr. Biocca was a chemist with many years experience in soldering technologies. He presented around the world in matters relating to process optimization and assembly. He was the author of many technical papers delivered globally. Mr. Biocca was a respected mentor in the electronics industry. He passed away in November, 2014.
The main reason for these issues it looks to be inadequate heat applied to the assembly (in the pre-heating process and/or soldering process) - basically the assembly gets too hot. Items to consider: the geometry and the population of the board and the parts that needs selective soldered. Depending on these things, you will have to carefully choose your fluxing, preheat temperature, slope and duration, nozzle size, dwell time, etc. Engineering and Operations Management Independent Consultant Georgian Simion is an independent consultant with 20+ years in electronics manufacturing engineering and operations.
Contact me at georgiansimion@yahoo.com. Solder balls can be created from several different factors during the process. Sometimes it's just a matter of too much flux. But my opinion is when this occurs on the top side while you are soldering in the bottom side, it's probably because of too much moisture int he board. As far as the reflowing,this is typically because you have too much heat from the selective nozzle while soldering and/or you have heated N2 set too high (if you are using this feature). It's very important to use the right size nozzle for the job. Many times people will have a nozzle that is too small. A smaller nozzle has less energy and you need to dwell too long to get a good joint (By the way, this can also make solder balls). When ever possible, use a bigger size nozzle. Hopefully you have a machine with dual nozzles so you canhave a big nozzle and a small nozzle at the same time. Another option if your volume allows this is to use selective stamp soldering. This is a process which solders the entire PCB at once using dedicated volumetrically controlled nozzles (with no pumps) which is very fast. With this type of process there are virtually NO machine generated solder balls, and you will NEVER have a problem with reflowing surface mount components. The process is controlled such that you can expect very high FPY. National Sales and Marketing Manager, North America Business Development Manager, DAGE | X-Ray component counting Mr. O'Neil has been in the electronics manufacturing industry for over 20 years.
