Test-Research-Inc.
Test Research, Inc.
October 21, 2024 - Updated
April 24, 2013 - Originally Posted
Jumper Wire Gauge
Is there a recommended gauge and insulation type for standard circuit board jumper wires? Is there a suggested insulation color? Can you point me to any specifications or standards.
G.S.
Jumper wires on circuit boards can take a couple of forms. If you must use through hole, bent solid wire jumpers are the only practical choice and most likely added by hand. If you can change to an SMT layout for the jumpers, you can use zero Ohm resistors which have the advantage in that you can place them by machine like any SMT resistor.
In both cases, the current these jumpers must carry will determine the gauge or package size (higher current means larger gauge or SMT package size). Refer to wire gaga ampacity charts to select the wire gauge or the zero Ohm resistor's manufacture's data to make sure you have the needed size to carry the expected current. If the current they carry is low (mA), then the only reason to select a larger gauge is to make it easy to place or easy to read the value, so you know that the SMT part that looks like a resistor is really a jumper (0 Ohms),or otherwise make it easier to handle during the assembly process.
I know of no insulation color standards for jumpers, however, most jumper wires use a Teflon based insulation (PFA) which will not melt at solder temperatures. Teflon insulation is naturally white, making it the most common color and is likely the lowest cost. Although Teflon based insulations can be found in other colors, unless there is some desired color for athletics reasons, white is the most common.
Paul Austen
Senior Project Engineer
According to IPC-7721, Section on Jumper Wires, section 6.1, in the Jumper Wire Selection section #5 states: "Recommended wire is solid, insulated, plated copper wire, 22 to 32 AWG with a heat resistant insulation. Wire with tin-lead plating may be restricted due to environmental laws."
As for the color, that is up to you, but keep it simple from the perspective the function of the particular wires. For example ECO wires to the board, could be green, whereas jumper wires due to etch defects could be red, and so on, so by looking at the board, one could distinguish between the functions of the wires.
Therefore the sections from IPC-7711/7721 is section 6.1 and from IPC-A-610 it is section 7.5.4.1 on page 7-72.
Good answer, Leo. I would also like to point out two things. The IPC 7711/7721 standard also provides a chart to show you the wire gauge that will provide the same current-carrying capacity as the old trace, based on the original trace width.
Also, use of Teflon-insulated wires as jumper wires may not be a good idea due to the Teflon's inclination to cold-flow away from any pressure point. So if it is pushed or routed against any exposed metal lead or other conductor, it can flow away, allowing an electrical short.
Many high-rel companies use magnet wire and coat over the varnish with a good epoxy as the final step. This is a very reliable method.
Richard D. Stadem
Advanced Engineer/Scientist
General Dynamics
