February 20, 2025 - Updated January 8, 2013 - Originally Posted Epoxy Wicking up Wire InsulationWe have 13 gauge insulated wires soldered directly into plated holes in a circuit board. The board is placed inside a plastic housing and filled/potted with epoxy. During the curing process, the epoxy "wicks" up the wire inside the insulation and hardens. This reduces the flexibility of the wire beyond the filled area. Can you suggest ways to eliminate the wicking of the epoxy up the wires so the wires remain flexible? T.J. |
Higher Viscosity epoxy. Or softer hardness.
You don't say how many wires per circuit board, or how many circuit boards you need to do this to, so the solution I suggest may not be practical. I saw this issue in an automotive components manufacturer who needed to pot the CCA inside of a plastic housing just to protect the electronics from the harsh under-the-hood environment, and they also had an issue with the loss of a flexible harness at the point where the wires exited the potting material. The good news is that there are potting materials that are cured instantly using UV radiation. A two-stage potting process can be used. In the first stage, an automatic dispenser can be used to dispense a fairly thick UV-curable potting component on top of the solder joint at the point where the insulation of the 13-gauge wire ends. Then the CCA is subsequently passed under the UV curing conveyor which flash-cures the first-stage potting, sealing the insulation before any has time to wick up the wire underneath the insulation.Then the entire CCA can be potted inside of its enclosure, and the first-stage potting prevents any of the second-stage potting material from wicking under the wire. CAUTION: Selection of the first-stage potting material requires qualification. It must be compatible with the solder joints,the insulation on the wires, and lastly the 2nd-stage(currently-used) potting material. For example, there are certain UV-curable RTV compounds that can be used, but they MUST be electronics-grade RTV materials, as some RTVs will attack solder joints. I suggest you talk to your current potting vendor if you haven't already. They may already have a solution to this issue, because this is not unique to your product. If they don't have a solution, contact the folks at one of the following companies. They both represent a large number of product lines, and both have experts available that can help you find a compatible solution. Just remember, qualify whatever product you choose. You may need to run some humidity testing as well as other testing to ensure the materials are indeed compatible and will withstand the environment in which your product is intended to be used. You don't want to trade your current problem with a worse one that does not manifest itself until much later! Contact the folks at one of the following companies for help: www.hisco.com/ and www.ellsworth.com
Heat-shrink sleeve would that work???
Three opportunities present themselves:
The second option also may be feasible; if you are using an elevated-temperature curing process, the elevated temperature can drastically drop the viscosity of the un-cured potting material, which will dramatically increase wicking. Dropping the temperature of the curing process, at least until partial cure has been attained, may be a solution. If you are using a vacuum to de-gas after potting, this can also dramatically increase wicking. It may not be possible or desirable to eliminate the vacuum step, however. The third option is a sure fix, but requires an additional material, and potentially an additional curing step, to seal around the wires.
