Test-Research-Inc.
Test Research, Inc.
August 27, 2012 - Updated
August 21, 2012 - Originally Posted
How to Remove Adhesive Bonded Resistors
We have a board that was originally built using an adhesive and probably a wave solder process. We need to rework some of the resistors on the board and are not sure of the method to remove them. Using two soldering irons we can quickly melted the solder, but the parts do not come off the board. Any suggestions for removing the resistors? We have hundreds of resistors to remove.
M.H.
A"hot tweezer" adapter for a soldering station probably will do the trick forremoval. It will heat both joints and the component can then be gently rotatedto break the adhesive bond and lifted. Alternatively, a hot air gun can be usedto heat the component and reflow both joints, and a tweezers can then be usedto gently twist the component to remove it. Any process that you use needs tobe qualified to set the process parameters such that the PWB and surroundingcomponents are not damaged. When reworking multilayer ceramic chip capacitors,I suggest a hot air process to minimize thermal shock, especially for largercomponents.
I would suggestthe use of Thermal Soldering Tweezers. This tool features two heated points ina tweezer configuration. The heated tips will reflow the solder joint on bothsides of the chip simultaneously and allow you to grasp the chip with security.Once the soldering has fully melted you can give the chip a slight twist tobreak the glue joint and lift the chip from the board. IPC 7711 method 3.3.2lists the full, step-by-step procedure See: IPC-7711B-7721B_Chip_Component_Removal_Tweezer_Method.pdf
Kris Roberson
IPC
