March 4, 2024 - Updated August 1, 2012 - Originally Posted Silver Solder for Audio CircuitsWe manufacture an audio product. We have been told to use silver solder for all solder connections. Can silver solder possibly have any impact on the quality of our product, or will standard, lower-cost eutectic solders work just as well? S.L. |
Compared to conventional tin & lead alloys, a much greater corrosion favoring effect exists with silver-based solders due to the high solubility rate of silver hydroxide in moisture films and the low critical relative humidity of 60%. In particular, carboxylic acid-based activators in solder pastes can result in a steady increase of the adsorbed moisture film. It is therefore possible that the value of the critical humidity level could drop below levels that are typically found in air-conditioned rooms. The removal of hygroscopic residues(carboxylic acid, salts) through assembly cleaning can contribute to a significant improvement of resistance to elevated humidity levels and reduce susceptibility to migration. The phenomenon can be explained by the uniform distribution of the silver with a maximum of 4% in the soldered joint. The electro-chemical migration mechanism activates only the silver that is close to the surface of the soldered joint. This means that only low concentrations of silver hydroxides are available. Accordingly, only filigree dendrites with a very low current-carrying capacity can be formed. These dendrites lower the surface resistance primarily in the final stage of their growth, but are then burnt off by a short-circuit effect so that the original surface resistance is re-established. At normal (ambient) temperatures, the rate of renewed silver supply to the surface of the solder joint is slower than the attack by electro chemical migration. This is the reason why short-life bridges are repeatedly formed that have never transformed into constant short-circuits. This phenomenon results in inexplicable defect patterns in electronic assemblies that cannot be systematically repeated and not be discovered by discontinuous resistance measurements.
All elements of the conductive path for audio signals have the potential for adding"noise" (aka: hiss, buzz, hum, etc) to the audio signal. Resistors are one of the most common sources of noise in audio circuits, carbon film being one of the worse, so most will use a lower noise generating resistors such as: metal file, wire wound, carbon comp, or foil type resistors, each having a trade-off between noise generation, size, and cost. It stands to reason that solder joints can also add noise, since the audio signal may pass through hundreds of solder joints on its way to your ears. Audio "purists" recommend a silver alloy solder, usually around 4% Ag. The use of a silver solder in audio equipment can be one the many hidden differences between lower priced audio products and "high end" professional audio equipment.
I would venture to say following.
What is the composition of the silver solder? What are the reliability requirements? There are lower-temp eutectic alloys (cheaper or more expensive) that can be used based on the reliability requirements, solder process, equipment used.
I agree with Jerry K's points (2) and (3). In addition, let me offer some insight into what may be driving the advice to use a silver-bearing solder. Silver is the best-available electrical conductor, and has a long history in electronics. Audiophiles are a notoriously superstitious bunch, and have shown a shocking tendency to believe technical claims that have not been demonstrated to have an *audible* effect on equipment performance. So, can a silver solder really improve the sound of the resulting equipment? Perhaps, but I am somewhat dubious. We could talk all day about skin effects, thermal (Johnson-Nyquist) noise, etc., but the bottom line is, if there is an audible effect, it should show up as detectable signal degradation at the frequencies of interest. The whole question may be somewhat moot, however. If the assemblies you are producing are Pb-free, then it's easy to select a Sn-Ag-Cu solder that contains approx. 4% Ag. The cost difference between that and lower-Ag alloys is not that great.
I used to run my own Contract Electronics Manufacturing company in a previous life. As part of that I built extremely high-end audiophile pre-amps, drives, peripherals, and amplifiers for two internationally-recognized audiophile companies, one of which has what may be the very best system in the world installed in the White House. While the components they use were very high-end, such as Caddock precision resistors, etc., they all used standard SN63/37 solder at that time.They use instrumentation to measure sound purity, tonal harmonization, signal-to-noise performance, etc., and relied primarily on high-end tubes rather than more conventional transistors (and they still do). The difference in performance between their products built with Sn63/Pb37 solder versus 4% silver solder? None whatsoever. From a human discernment standpoint, even those with the best hearing picked the Sn63 solder just as often as the 4% silver solder, at an even 50% rate. The world's best singer, Sissel Kyrkjebo, sounds just as clear and incredibly pure no matter whether the device being used is soldered with SAC305, Sn63, or SN100C. When you listen to her voice, the type of solder used quickly becomes very irrelevant.
