February 28, 2024 - Updated June 5, 2012 - Originally Posted BGA Die and Pry Testing
J.J. |
I would need more information to make the determination as to whether or not these are Kirkendall voids, as Kirkendall voids are at the intermetallic layer and this cannot be determined from these pictures. The other issue is what alloy was the solder balls on the BGA and what solder alloy was used as solder paste? The right hand pictures displays penetration of the dye around the circumference of the pad so I would guess that the pad was not completely wetted with the base solder alloy or this is where the fracturing of the solder joint started to occur. In either case more information would be needed to fully assess the situation.
In short, I think it's unlikely that the root cause of the observed defect is Kirkendall voiding. What's needed for root cause analysis is a detailed analysis of the surface and subsurface metallurgy. Dye & pry has told you that some crack propagation has begun Perhaps not unexpected at 500 cycles. Now you need to bring the appropriate tools and methods to get to root cause. What I would do is:
The amount of dye penetration looks too extensive for Kirkendall voids.Are the images showing ball separation from the chip?
I don't think that it's Kirkendall voiding. It looks like poor wetting/bad adhesion. After 500 cycles it may be strain due to TCE mismatch affecting the solder (creep/fatigue failure). Do you underfill?
President, Consultant Process Solutions Consulting Inc. Lee Levine has been a Process Engineer and Metallurgist in the semiconductor industry for 30 years. He now operates his own company Process Solutions Consulting Inc where he consults on process issues and provides SEM/EDS and metallography services.
Without additional information it is difficult to be definitive on the voids shown in the picture. Kirkendall voids are typically irregular in shape and only a few microns in size, although there is no scale on the pictures these look to be much larger in size and appear to be spherical in shape. Also I would expect more of them if they were Kirkendall. It is extremely difficult to rework voids out of array components so I doubt that reworking parts will help. Finally The pictures do not appear to show die penetration in to any of the voids so the voids may not be the cause of the failure.
While there is not enough info to make a sure call, I took your pictures and magnified them using a net camera system. I can tell you: 1)They are not Kirkendal voids. 2) The dye appears to have penetrated very little, if at all. 3)The image of the single pad shows evidence of oxidation of the copper in areas that did not wet, while some wetting did take place. 4)The image of multiple balls shows some voiding at some of the PWB pads, but not all, and some partial voids that did NOT reach down to the board pad. 5) The soldermask extends up to the edges of some of the pads, but not others, which is something I have not seen before. The only summary I have based on those two pictures alone, is that what voiding you are seeing is probably not a concern nor a reliability issue because where there are some small voids there is also very good evidence of good wetting around all of the voids, and none appear to be larger than 20% of the pad diameter. The bigger concern to me are the pads that show what appears to be oxidized copper with minimal wetting PLUS solder mask right up to the pad. This APPEARS to be evidence of oxidation, and during cycling the soldermask will actually apply tremendous pressures on the pad/solderball, causing extrusion of the solder resulting in complete separation. The reason for no dye penetration on that one? It appears you had wetting completely around the circumference of the pad, but not in large areas on the pad itself. Suggestions: Perform EDX on the both the board pads prior to assembly and those that look like the one in the picture after dye and pry. You may want to also X-ray the parts prior to assembly and reflow to see if the voids are present as received, and to what extent, just to rule them out as a cause. If the BGAs themselves show no evidence of voids or other issues, you may wish to evaluate other pastes or your paste handling system from dock to printing, but I would focus on the pad oxidation issue first with the fabricator.
