AIT ORMET® TLPS for Component Attach
AIT ORMET®TLPS is proven for outstanding reliability for component attaches and MLCC build-up for high temperature applications beyond 175ÂșC
Ormet® TLPS
Nordson-ASYMTEK
High-Density Rigid PCB Boards
Summit's rigid capabilities include HDI high-layer count boards, staggered microvias, blind/buried vias, multiple sequential lam, via fill, metal backed/metal core, and oversized panel options.
May 22, 2012 - Updated
May 22, 2012 - Originally Posted
Wave Solder Dross Contamination
We have a problem with out tin/lead wave soldering system.Dross particles are sticking to the PCB and some are not found during visual inspection, but detected during in-circuit test. The solder pot has a turbulentwave and a laminar wave and no nitrogen supply is used. The system has a wax cage to protectpump shafts. The wax cage uses specialmineral oil. What could be the cause of the contamination and how can we prevent it?
H.R.
Several process issues could cause dross sticking to the board. One being solder pot maintenance, dross may form on the walls orat hot spots in the solder spot or the impeller region. So here regular cleaning of the solder pot can reduce dross frombeing carried out of the pot via the impeller system. Temperature should be keep to lower limits if possible in 63/37the limits are 465-500F for lead-free it is 510-540F. Lower temperatures create less dross within the pot and impellersystem. Using solder withlower impurities levels also helps since some elements enhance dross formation.Regular analysis is recommended.
Peter Biocca
Kester
SAWA SC-BM500E Automatic Stencil Cleaner
Ultrasonic combined with spray cleaning provides an excellent solution for all kinds of applications including wafer bump and electroform stencils.
