Sponsor |
Circuitnet Media LLC
Ask the Experts |
May 2, 2012 - Updated
April 24, 2012 - Originally Posted
Solder Mask Mis-registration Issue
I have a situation where solder mask wasmis-registered and is covering a portion of the pads for amicro-bga.
What percent reduction in pad areais acceptable while maintaining a reliable solder joint for commercialapplications?
R.L.
Expert Panel Responses |
Let's start with the industry specifications; IPC-6012 statesthat no encroachment of mask on non-soldermask-defined BGA lands is allowable,except of course at the conductor attachment point. The reason behind this isthat the BGA solder joint takes up all the thermal and mechanical stresses betweenthe component and board, unlike leaded parts where the leads absorb some of therelative movement. For this reason, things that reduce the solder joint area,or create "stress risers" (sharp internal corners) are to be avoided.
The reliability impact for your specific situation depends on alot of factors, and a detailed analysis would need to be done to determine thelevel of risk. The bottom line, though, is that if the PWBs were purchased toIPC-6012, they do not conform.
Suppliers can nearlyalways hold soldermask registration within a true position of 0.003". Supplierswith more modern imaging technology may be able to hold 0.002". You don't saywhat pitch your part is, but it looks to me like the soldermask registrationmay be close to accepted registration tolerances. You will need to look at thedesign vs. the supplier's process capability to determine whether changes tothe design may make it more producible.
I would say there should be no tolerance to resistbleed onto BGA pads. Mostly because there are Plasticizers that are very clearthat can creep out from the main body of the resist and reduce actual wettingto the pad. But obviously the BGA ball will still melt and may look perfectlyfine but be a future issue electrically and mechanically.
Greg York
Technical Sales Manager
BLT Circuit Services Ltd
Sponsor |
