Nordson-ASYMTEK
A Lifespan of Reliability
Nordson Electronics Solutions makes reliable electronics an everyday reality. Selective soldering, dispensing, coating, and plasma solutions.
Circuitnet Advertising Delivers Results!
Vapor Phase Profiling
Thermal profiling the vapor phase soldering process – especially those with vacuum – is challenging. ECD's M-VP™ sealed barrier can take it. Learn more.
August 30, 2024 - Updated
March 20, 2012 - Originally Posted
Reflow Causing Warp
We have a 20 layer PWB that is not balanced, 8 of 10 - 1oz cu layers in the bottom half vs 2 of 10 - 1 oz cu layers in the top.
The board bows during reflow. There is a long SMT connector that is mounted to the convex side and the end leads stick up off the board and do not form a solder connection. The board later gets mounted flat into a housing. Currently we are hand soldering the open connector leads after reflow.
Other than a better design, what can be done prior to reflow, during reflow, or post reflow, to prevent the board from warping?
J.W.
You can take the following precautions.
  • Check that the PCB House is giving the board a 'slow cool' or secondary 'annealing'.
  • Review the problem with your PCB house. They can sometimes suggest a different glass weave,and/or direction to help.
  • Ensure the storage of the PCB is dry, by keeping it in a dry cabinet.
  • Check that the board warping is not related to weight and temperature. You can increase the grade of FR-4 if that is your laminate, to 406 or better Tg material and you might consider a pallet, or edge support to provide rigidity over the weight/span oft he PCB in the oven.
Sounds like fun. Kooky designers are notorious for putting target on production team.
Rodney Miller
Specialty Coating Systems
If you are stuck with the design, then the only recourse is to mitigate the warping. If there are mounting holes available in the center of the board, it may be possible to use a fixture to hold the board flatter during reflow.
Such a fixture is not a clean solution either. It would most likely have to be applied after printing and placement but prior to reflow. As such there is a risk of knocking components off lands when installing the fixture.
You should also be concerned about the residual stresses in solder joints and bending stresses on components with such a design. The SMT connector is soldered to a convex surface, and as the board cools, it flattens again, warping the connector into a concave shape and applying mechanical stress to the joints and leads.
You should try to gain an understanding of whether this is a reliability risk.
IIT offers titanium board stiffeners that will assist with stabilizing the board during reflow. They easily slide on to the edge of the boards, and will keep the board parallel during reflow.
Depending on how imbalanced the inner layers are, the potential remains for warping once the stiffeners are removed after reflow.
Stephanie Nash
Director
Stephanie Nash is the Director of Technical Services & Marketing for Integrated Ideas & Technologies, Inc., a premier manufacturer of SMT stencils. She has been instrumental in the stencil design and technical support.
"We have a 20 layer PWB that is not balanced..." That really says it all. Your only recourse will be to restrain the results of this DIM-challenged design with stiffeners.
No amount of moisture mitigation, temperature control and weave re-direction will remedy 20 mis-matched layers of thermally induced material tension. If you do use stiffeners I recommend not taking them off until the assemblies truly return to room temperature.
Robert "Bob" Lazzara
Circuit Connect, Inc.
I do not know how practical any of these suggestions are but you could look at a fixture to hold the board flat in the area of the connector. a second approach would be to use a stepped stencil to put additional paste on the end pads (you will need to be careful the you do not get bridging because of the extra metal).
Finally you could consider over printing the offending pads (length ways only if space permits) so that when the paste reflows the solder height on the problem pads will be higher and hopefully bridge the gap.
Neil Poole
Senior Applications Chemist
Henkel Electronics
You must run a thermal profile first to find where the temp differences are on the board. Warp is caused by temperature difference for the most part. This is difficult to solve sometimes because a reflow oven is designed the heat uniformly and your product is not so uniform.
If the difference top to bottom, you can use your oven's top vs bottom settings to increase the temp on the cooler surface of the board. If side to side, you could try rotating the board 90 deg so the whole cooler side enters the oven at the same time.
If only one smaller portion of the board is cooler, the best thing is to "shield" the hotter portion with a thin layer of insulation material, like PCB material cut to size so the board heats more evenly. In a sense, make up for the design deficiencies by adding or balancing the assembly's heating rate to make it more uniform.
Paul Austen
Senior Project Engineer
For your warping issue, a mechanical metal stiffener is required prior to the soldering or reflow operation. There is no other way. Large PCBs with heavy components will warp during the soldering or reflow operation. The only way to prevent this is to design in make room and install PCB stiffeners onto the board prior to soldering. Compufab Inc. has provided millions of PCB stiffeners to multi-national electronic companies world wide with great success.
Otto Steiner, Compufab Inc
Touchless Solder Ball Removal
Viscom
