March 5, 2012 - Updated
February 26, 2012 - Originally Posted
Black Land Edges
Black Land Edges
After vapor phase assembly of a class 2, 10-layer HDI board, the inner edges of the lands of plated through holes have turned slightly black. In the cross-sections of the board we cannot find any irregularities regarding the Cu and NiAu plating. What might be the root cause for this?
A.V.
Couple of questions.Does the black material clean off? What type of preheat are you using?Solder and flux type?I'd be happy to help as I can but I'll probably need to get a bit deeper intothe process.
David Suihkonen
R&D Technical Services Inc.
David is President at R&D Technical Services, a vapor phase reflow oven manufacturer. he has 20 plus years experience in the vapor phase reflow industry.
I'll make the assumption that the Ni-Au finish is ENIG, meaninga very thin Au layer, less than 6µin. I can think of two scenarios that mightlead to the localized black color:
  1. Exposed Ni which has reacted, perhaps with oxygen, to form ablack oxide or other compound
  2. An organic material was present on the surface, which wascharred during heating to form the black deposit
I'd regard scenario 1 as the most likely. It's not normallypossible to see the Au layer directly in a micro-section. The thickness of less than6 µin is equivalent to 0.15 µm or 150nm, which is well below the acceptedresolvable feature size for optical microscopy. The fastest, easiestmethod to get to the bottom of this is to examine the area using a SEM(Scanning Electron Microscope) equipped with EDX (Energy Dispersive X-ray)capability. This will tell you rapidly what the elemental composition of thearea is, and how it differs from the nearby areas. This will tell you whetherthere is exposed Ni, or whether there is any organic material present onthe surface. XRF (X-Ray Fluorescence) will not work due to the size andposition of the blackened area. A good metallurgical lab can provide theSEM/EDX analysis as a service. Do be aware that SEM maximum sample sizes aretypically small and you should consider this a destructive test, as a sectionof the PWB may need to be removed for analysis.
Thegold at the edge of pads and at through hole can be substantially thinner thanover the rest of the pad. This would be very difficult to see in an x-sectiondue to the extremely thin plating thickness. The black color is probably thenickel oxidizing after the reflow process.
Richard Boyle
Global Product Champion
Henkel Electronics
