Test-Research-Inc.
Test Research, Inc.
March 7, 2012 - Updated
February 26, 2012 - Originally Posted
Variation in Solder Paste Thickness
We have two openings within one 5 mil laser cut stencil; one with dimension 0.32 x 0.30 and another with dimension 0.27 x 2.05. We notice that the smaller openings tend to have higher solder thickness. Our solder print system has a pressure set at 3 kg and speed of 15 mm/s. How should we go about to improve the thickness so that both openings have similar thickness?
A.P.
I believe your answer lies in the "edge effects." The smaller aperture has an area ratio, AR(1) of 0.62. This is pretty aggressive, but printable with good stencil manufacturing, good paste, good substrate gasketing, and good process control. The longer aperture, although narrower, is much easier to print (AR = 0.94) because of its length.
If you look carefully at the height profile of the printeddeposits(2), you'll find that near the edges of the apertures, you have raisedpeaks of paste. This effect is greatest in corners. The peaks contribute more to the average height measurement for small apertures because they make up a greater percentage of the overall area of the deposit. This is especially true because many paste measurement systems include only the area where the paste height is above some threshold value.
If your paste measurement system reports the area of the deposits, you should notice that the deposit area is smaller than the theoretical area of the aperture. Small apertures will result in lower volume than expected, even though height may be greater than expected. Volume is the parameter on which you should focus, or more specifically, the transfer efficiency. Transfer efficiency is the actual deposit volume divided by the theoretical volume of the aperture. For your 300um W by 320um L by 127um H aperture, I expect you will see about 70%transfer efficiency. For the 270um W by 2050um L by 127um H aperture I would expect a transfer efficiency of about 90%.
If your numbers are much worse than this, you will need to conduct focused, controlled process experiments to determine why.
  1. AR is defined as the ratio of aperture open area to aperture wall area
  2. Try viewing deposits under a stereo microscope using a point source of light from a low oblique angle, perhaps 10 to 15 degrees above the horizontal. An example of this technique is shown in the attached photo. Notice the edge peaksand the differing shadow lengths.
Thelikely cause is that the paste is being robbed from the slightly largeraperture / pads. It may sound strange but the best way of overcoming this andmaking the result more even would be to increase the print speed, aim foraround 30 - 70 mm/sec depending on what the paste can cope with.
Richard Boyle
Global Product Champion
Henkel Electronics
