Test-Research-Inc.
Test Research, Inc.
November 16, 2011 - Updated
November 14, 2011 - Originally Posted
Mixing Solders
Is there a problem if the following 2 solderchemistries are mixed on a PCBA? Sn96.5 Ag3.0 Cu0.5 and Sn95.5 Ag4.0 Cu0.5
M. D.
Absolutelynot, for all practical and most physical and chemical reasons, they areidentical before,during and after the soldering process so mixing them wouldhave no effect.
Richard Boyle
Global Product Champion
Henkel Electronics
